Setting up zoneminder (1.34.20-buster1) ...
Detected db service is mariadb.service
Updating permissions
Initiating database upgrade to version 1.34.20 from version 1.34.19
Upgrading database to version 1.34.20
Loading config from DB 230 entries
Saving config to DB 230 entries
Upgrading DB to 1.34.20 from 1.34.19
mysql: unknown variable 'bind-address=0.0.0.0'
Output:
Command 'mysql -hlocalhost -uzmuser -p'zmpass' zm < /usr/share/zoneminder/db/zm_update-1.34.20.sql' exited with status: 7
Freshening configuration in database
Migratings passwords, if any...
Done Updating; starting ZoneMinder.
Job for zoneminder.service failed because the control process exited with error code.
See "systemctl status zoneminder.service" and "journalctl -xe" for details.
invoke-rc.d: initscript zoneminder, action "start" failed.
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Sat 2020-09-05 14:16:13 PDT; 6ms ago
Process: 4068 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=255/EXCEPTION)
dpkg: error processing package zoneminder (--configure):
installed zoneminder package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
zoneminder
E: Sub-process /usr/bin/dpkg returned an error code (1)
Output:
zoneminder
