New install Can't create frame capture images from video because there is no video file for this event then more problem
mlw19mlw91
Post by mlw19mlw91 »
First I get the problem : "Can't create frame capture images from video because there is no video file for this event"
so I try very carefully to set my timezones assuming it could be a timezone mis match because my timezones were all wrong. That didn't fix it at all.
So now I stopped the services to be able to upgrade without an error
sudo service apache2 stop
sudo service zoneminder stop
Then I run
sudo apt full-upgrade
it updates from 1.34.10 to 1.34.16
during setup I did notice the following note:
Current default time zone: 'America/New_York'
Local time is now:      Wed Sep 16 10:25:36 EDT 2020.
Universal Time is now:  Wed Sep 16 14:25:36 UTC 2020.
Run 'dpkg-reconfigure tzdata' if you wish to change it.
So I'm not sure if that indicates a time zone problem again after the update.
During install I get the following message:
 php.ini: A new version (/usr/lib/php/7.3/php.ini-production) of         │
  │ configuration file /etc/php/7.3/apache2/php.ini is available, but the   │
  │ version installed currently has been locally modified.                  │
  │ What do you want to do about modified configuration file php.ini?       │
  │          install the package maintainer's version                       │
  │          keep the local version currently installed                     │
  │          show the differences between the versions                      │
  │          show a side-by-side difference between the versions            │
  │          start a new shell to examine the situation                     │
  │                                 <Ok>
I am not sure what to do so first I view the side by side difference to copy it for future repair
 Line by line differences between versions
  │ --- /etc/php/7.3/apache2/php.ini root.root 0644 2020-04-29 14:38:06
 │ +++ /usr/lib/php/7.3/php.ini-production root.root 0644 2020-07-05
 │ 02:46:45
 │ @@ -953,7 +954,6 @@
 │  ; Defines the default timezone used by the date functions
 │  ; http://php.net/date.timezone
 │  ;date.timezone =
 │ -date.timezone=Europe/London
 │  ; http://php.net/date.default-latitude
 │  ;date.default_latitude = 31.7667
 │ @@ -1415,7 +1415,8 @@
 │  session.cookie_httponly =
 │  ; Add SameSite attribute to cookie to help mitigate Cross-Site Request
 │ Forgery (CSRF/XSRF)
 │ -; Current valid values are "Lax" or "Strict"
 │ +; Current valid values are "Strict", "Lax" or "None". When using
 │ "None",
 │ +; make sure to include the quotes, as `none` is interpreted like
 │ `false` in ini files.
 │  ; https://tools.ietf.org/html/draft-west-first-party-cookies-07
 │  session.cookie_samesite =
 │ @@ -1423,12 +1424,9 @@
 │  ; http://php.net/session.serialize-handler
 │  session.serialize_handler = php
 │ -; Defines the probability that the 'garbage collection' process is
 │ started
 │ -; on every session initialization. The probability is calculated by
 │ using
 │ -; gc_probability/gc_divisor. Where session.gc_probability is the
 │ numerator
 │ -; and gc_divisor is the denominator in the equation. Setting this value
 │ to 1
 │ -; when the session.gc_divisor value is 100 will give you approximately
 │ a 1% chance
 │ -; the gc will run on any given request.
 │ +; Defines the probability that the 'garbage collection' process is
 │ started on every
 │ +; session initialization. The probability is calculated by using
 │ gc_probability/gc_divisor,
 │ +; e.g. 1/100 means there is a 1% chance that the GC process starts on
 │ each request.
 │  ; Default Value: 1
 │  ; Development Value: 1
 │  ; Production Value: 1
│ @@ -1436,13 +1434,9 @@
 │  session.gc_probability = 0
 │  ; Defines the probability that the 'garbage collection' process is
 │ started on every
 │ -; session initialization. The probability is calculated by using the
 │ following equation:
 │ numerator and
 │ -; session.gc_divisor is the denominator in the equation. Setting this
 │ value to 100
 │ -; when the session.gc_probability value is 1 will give you
 │ approximately a 1% chance
│ -; the gc will run on any given request. Increasing this value to 1000
 │ will give you
 │ -; a 0.1% chance the gc will run on any given request. For high volume
 │ production servers,
 │ -; this is a more efficient approach.
 │ each request.
 │ +; For high volume production servers, using a value of 1000 is a more
 │ efficient approach.
 │  ; Default Value: 100
 │  ; Development Value: 1000
│  ; Production Value: 1000
 │ @@ -1458,8 +1452,8 @@
 │  ; (see session.save_path above), then garbage collection does *not*
 │  ; happen automatically. You will need to do your own garbage
 │  ; collection through a shell script, cron entry, or some other method.
 │ -; For example, the following script would is the equivalent of
 │ -; setting session.gc_maxlifetime to 1440 (1440 seconds = 24 minutes):
 │ +; For example, the following script is the equivalent of setting
 │ +; session.gc_maxlifetime to 1440 (1440 seconds = 24 minutes):
 │  ; find /path/to/sessions -cmin +24 -type f | xargs rm
 │  ; Check HTTP Referer to invalidate externally stored URLs containing
 │ ids.
I chose the following option:
"Install the package maintainer's version"
so it seems the new file has more info about the time zones, I decide to try the new one
For whatever reason the upgrade gets really hung up here:
Setting up libapache2-mod-php7.3 (7.3.19-1~deb10u1) ...
root@raspberrypi:/#
Progress: [ 96%]
I think it didn't update all the way because zoneminder was running in some way? I saw the following in the ZM logs:
2020-09-16 10:36:31	zms_m1		19335	ERR	Unable to connect to zmc process for monitor 1	zms.cpp	257
2020-09-16 10:36:31	zms_m1		19335	ERR	Unable to connect to monitor id 1 for streaming	zm_stream.cpp	53
2020-09-16 10:36:31	zms_m1		19335	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	578
I don't know why as it didn't happen last time. (my 2nd time trying this, maybe I hit a button?)
So I start it all again:
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to cor                                       rect the problem.
I run the configure option and then zoneminder starts with the following issues:
same problem
so I'm going to do another full install, is there a way to fix these issues if I encounter them again?
mlw19mlw91
Re: New install Can't create frame capture images from video because there is no video file for this event then more pro
ok after much trial and effort I got it to work again but not sure it had anything to do with my previous problem.
I reinstalled zone minder and I altered the default settings from my camera to h264 encode vs h264 passthrough.
I thought passthrough was better as it would use less cpu
In both cases I was able to download the video and view it on my PC but the zoneminder browser just didn't play any video when it was on the passthrough setting
burger
Post by burger »
Install guides are here:
wiki.zoneminder.com/Debian
wiki.zoneminder.com/Ubuntu
These are tested and working.
fastest way to test streams:
