Hi!
Just noticed when i open up a camera, and push the "Force Alarm" button bottom right of the popup window, it dows nothing at all. Also the button on the bottom left "Disable Alarms" does nothing,
Is this a bug, or some setting is not set correctly?
Thanks!
"Force Alarm" not working
Greetings,
Laszlo
Ubuntu Server 14.04.3LTS 64bit - ZoneMinder v1.32.3 - 2x AV-Tech AVN257 IP Cam; 1x Hikvision DS-2CD2020F-I IP Cam
Laszlo
Re: "Force Alarm" not working
I've noticed I need to set Options->System->AUTH_RELAY to "none" for the Force Alarm to work lately.
Thanks a lot, that solved this problem. I seti this to off and forcing alarm button is now working.
Greetings,
Laszlo
Laszlo
I would recommend you look at JS errors and or Apache/Php errors to see the real cause. Setting AUTH RELAYto none is not treating the core cause. It will also break zmNinja on mobiles. One of the real reasons for this problem: viewtopic.php?f=38&t=27544&p=107426&hil ... AY#p107378
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
this problem pops up and then disappears and then pops up again from version to version. I have not found the root cause so I should look at it closer. I have checked the time sync. These errors appear when Force Alarm is clicked on a monitor in Nodect mode
__
3-18 11:07:16 zmu 8208 INF Backtrace complete, please execute the following command for more information zm_signal.cpp 111
2019-03-18 11:07:15 zmu 8208 ERR Backtrace 6: /usr/local/bin/zmu(_start+0x2a) [0x557a406cd25a] zm_signal.cpp 104
2019-03-18 11:07:15 zmu 8208 ERR Backtrace 5: /lib64/libc.so.6(__libc_start_main+0xe7) [0x7f086bce0b97] zm_signal.cpp 104
2019-03-18 11:07:15 zmu 8208 ERR Backtrace 4: /usr/local/bin/zmu(main+0x2eb) [0x557a406caf9b] zm_signal.cpp 104
2019-03-18 11:07:15 zmu 8208 ERR Backtrace 3: /usr/local/bin/zmu(_Z9checkUserPKc+0x9) [0x557a4073e969] zm_signal.cpp 104
2019-03-18 11:07:15 zmu 8208 ERR Backtrace 2: /lib64/libc.so.6(+0xb1646) [0x7f086bd70646] zm_signal.cpp 104
2019-03-18 11:07:15 zmu 8208 ERR Backtrace 1: /lib64/libpthread.so.0(+0x12890) [0x7f086fe0a890] zm_signal.cpp 104
2019-03-18 11:07:15 zmu 8208 ERR Backtrace 0: /usr/local/bin/zmu(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x557a40733778] zm_signal.cpp 104
2019-03-18 11:07:15 zmu 8208 ERR Signal address is (nil), from 0x7f086bd70646 zm_signal.cpp 83
2019-03-18 11:07:15 zmu 8208 ERR Got signal 11 (Segmentation fault), crashing zm_signal.cpp 52
2019-03-18 11:07:15 zmc_m2 7998 INF Basement: images:527300 - Capturing at 10.00 fps, capturing bandwidth 67136bytes/sec zm_monitor.cpp 2490
2019-03-18 11:07:15 zmu 8199 INF addr2line -e /usr/local/bin/zmu 0x5648c4b25778 0x7ff968095890 0x7ff963ffb646 0x5648c4b30969 0x5648c4abcf9b 0x7ff963f6bb97 0x5648c4abf25a zm_signal.cpp 112
2019-03-18 11:07:15 zmu 8199 INF Backtrace complete, please execute the following command for more information zm_signal.cpp 111
2019-03-18 11:07:15 zmu 8199 ERR Backtrace 6: /usr/local/bin/zmu(_start+0x2a) [0x5648c4abf25a] zm_signal.cpp 104
2019-03-18 11:07:14 zmu 8199 ERR Got signal 11 (Segmentation fault), crashing zm_signal.cpp 52
2019-03-18 11:07:14 zmu 8199 ERR Signal address is (nil), from 0x7ff963ffb646 zm_signal.cpp 83
2019-03-18 11:07:14 zmu 8199 ERR Backtrace 0: /usr/local/bin/zmu(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x5648c4b25778] zm_signal.cpp 104
2019-03-18 11:07:14 zmu 8199 ERR Backtrace 1: /lib64/libpthread.so.0(+0x12890) [0x7ff968095890] zm_signal.cpp 104
2019-03-18 11:07:14 zmu 8199 ERR Backtrace 2: /lib64/libc.so.6(+0xb1646) [0x7ff963ffb646] zm_signal.cpp 104
2019-03-18 11:07:14 zmu 8199 ERR Backtrace 3: /usr/local/bin/zmu(_Z9checkUserPKc+0x9) [0x5648c4b30969] zm_signal.cpp 104
2019-03-18 11:07:14 zmu 8199 ERR Backtrace 5: /lib64/libc.so.6(__libc_start_main+0xe7) [0x7ff963f6bb97] zm_signal.cpp 104
2019-03-18 11:07:14 zmu 8199 ERR Backtrace 4: /usr/local/bin/zmu(main+0x2eb) [0x5648c4abcf9b]
FYI this was solved by Isaac in a recent commit. Rockedge confirmed it works. So please keep AUTH RELAY to hashed if you use zmNinja.
ES docs
zmNinja docs
ES docs
zmNinja docs
I am using ZM 1.34.16 (newbie) and still having this issue. Any suggestions?
Sorry for the bump, but I have to mention: if you set AUTH_RELAY to "none," and your ZoneMinder instance is listening to traffic from the internet, then you are allowing access to your direct camera feeds without any authentication. They won't be able to login to the UI, but if they use a link to your camera, it'll just display live video instead of a 4xx page. The links for every ZoneMinder installation uses similar routes, so this is really easy to guess, too.
I resolved this issue by setting a 64-character password. Mine was longer.
I saw this float through my web logs when I clicked the force alarm button, which prompted me to try this:
ERR [zmu] [password greater than allowed 64 characters]
