I have a RPi4 with ZM v1.34.16. Only one camera - chinese ONVIF HI3516EV100_50H20L_S38 (Hamrolte).
This is my first setup, I have added the camera as RTSP, in mode Mocord. I have setted up one Active and several Inactive zones.
The issue is, ZM is saving Events with no Alarms. 6*10min Events per hour - writing a lot to my SD Card.
I want only, that it saves the frames with alarms +/- some frames before and after.
Is it possible to do it? I was not able to find it in manuals, even with trying to find what to check out in settings or camera/event modes.
Otherwise, the SW looks really promising, saving me from buying chinese NVR.
Thanks for your help,
Michal, Slovakia
Mocord - saving everything instead of alarm frames only
Re: Mocord - saving everything instead of alarm frames only
OK, thanks,
Done that before (camera in Modect), but there was 0 events saved, even after I went to test the camera with my body.
So then if camera is in Modect, something is wrong with the zones, or sensivity...
