1.34 or 1.35
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
jacha05
1.34 or 1.35
Post by jacha05 »
Hi.
Should I go with version 1.35 or 1.34? Or is just 1.35 "beta"?
Re: 1.34 or 1.35
jacha05
Re: 1.34 or 1.35
Post by jacha05 »
Magic919 wrote: Sun Oct 11, 2020 7:25 am1.34.
Why is that? Please explain 8)
jacha05
Re: 1.34 or 1.35
Post by jacha05 »
Anyone else?
Re: 1.34 or 1.35
1.35 is bleeding edge development so unless you need some feature that is in 1.35, stick with 1.34.
klapa
Re: 1.34 or 1.35
Post by klapa »
iconnor wrote: Mon Oct 12, 2020 3:07 pm 1.35 is bleeding edge development so unless you need some feature that is in 1.35, stick with 1.34.
Hello, I am new to Zoneminder but like it and plan to use it. I need the ability to have cameras on two different network interfaces. I am running that now and believe that is the reason the ONVIF probe never finds anything even when I can use the ONVIF driver manager tool to configure these cameras. I was thinking from what I read here that v1.35 might help this issue.
Is V1.35 still planned for an October 2020 release date?
Re: 1.34 or 1.35
1.35 lets you select the network to scan so yes it will help.
No, I think January 1st is more likely.
klapa
Re: 1.34 or 1.35
Post by klapa »
iconnor wrote: Wed Oct 14, 2020 11:11 pm 1.35 lets you select the network to scan so yes it will help.
Thanks for the reply.
As I'm just building things I might try the development package in a VM.
