View Event & delete Event broken after last update
Hi, after I updated to 1.35.10~20201015172252-bionic I cant view recorded events any more.
If I click on them I just get HTTP Error 500.
Viewing/deleting the Events with zmninja-pro is still working.
Re: View Event & delete Event broken after last update
I also don't see anything but don't get 500 error
In Firefox you get empty screen in Opera HTTP Error 500
- knight-of-ni
HTTP 500 is a web server error, so check your web server logs.
Thats what I see in the Apache2 access.log
10.0.0.1 - - [16/Oct/2020:21:25:47 +0200] "GET /zm/index.php?view=event&eid=1641&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=MonitorId&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bop%5D=IN&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bval%5D=1%2C7%2C2%2C3%2C4%2C5%2C6&sort_field=Id&sort_asc=1&page=1 HTTP/1.1" 500 295 "http://10.0.0.2/zm/index.php?view=events&page=1&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=MonitorId&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bop%5D=IN&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bval%5D=1%2C7%2C2%2C3%2C4%2C5%2C6" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.121 Safari/537.36 OPR/71.0.3770.271"
Odd. Maybe I'm doing something different, but it seems OK on 1.35.10~20201015172252-focal on FireFox.
I updated today to 1.35.10~20201016145938-bionic.
But the problem still exist for me
Yes. Really odd.
Here, it works OK on focal,
but as you say on bionic.
BTW, I thought the timeline was fixed in the previous focal, but seems jumpy again these last two.
I just updated today too and get the 500 error now also in Chrome. White screen in Firefox. Was hoping for a fix to the other issue I had but now I can't even view recordings.
- knight-of-ni
Working just fine here.
If you want to help, then post your Apache error log (not access log), showing the HTTP 500 error message.
ok thats what i find in the error.log
[Mon Oct 19 03:07:39.801500 2020] [php7:emerg] [pid 19514] [client 10.0.0.1:58113] PHP Parse error: syntax error, unexpected ')' in /usr/share/zoneminder/www/skins/classic/views/event.php on line 219, referer: http://10.0.0.2/zm/index.php?view=events&page=1&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=StartDateTime&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bop%5D=%3E%3D&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bval%5D=-1+day&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bcnj%5D=and&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Battr%5D=MonitorId&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bop%5D=IN&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bval%5D=1%2C7%2C2%2C3%2C4%2C5%2C6
- knight-of-ni
Thank you. That's was extremely helpful.
Looks like this is what caused the issue:
https://github.com/ZoneMinder/zoneminde ... e9c5c39b13
I'll let Isaac know.
- knight-of-ni
My knee-jerk reaction to that error message is to remove the trailing comma on line 218 in event.php:
to:
I might be wrong, but it can't hurt to try it.
function($r){return $r >= 0 ? true : false;},
Thanks that fix worked.
About the event delete. After I deleted all Events it seams to work again. Bevore I did this I was not able to delete single checked events in the list. Strange...I will keep an Eye on this.
