[SOLVED] Changing database location
whoop
Post by whoop »
I am trying to change the default location of the mysql data directory.
I think I did everything correctly and when I run:
select @@datadir;
in a mysql session I get the new data location.
However when I try to start zoneminder I get the following error for zmpkg.pl in the logs (and zoneminder fails to start):
ERR [Error reconnecting to db: errstr:Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) error val:]
The /var/lib/mysql/mysql.sock is still the old location and I don't know where zmpkg.pl (or zoneminder) is getting this location from.
Re: Changing database location
One is the data directory, the other (which errors) is the socket for MySQL to connect to. Two different things.
whoop
Post by whoop »
Valid point.
However I was under the impression that moving the entire directory and than editing /etc/my.cnf.d/mariadb-server.cnf:
[mysqld]
datadir=/new/mysql
socket=/new/mysql/mysql.sock
would also solve the socket problem..
The mysqld service seems to be running fine (select @@datadir; gives me the proper new location).
httpd service seems to be running fine.
Only zoneminder service still fails while pointing at the old socket location --> /var/lib/mysql/mysql.sock in the error.
journalctl -xe:
-- Unit zoneminder.service has begun starting up.
Oct 23 16:08:21 testserver zmpkg.pl[4130]: DBI connect('database=zm;host=localhost','test',...) failed: Can't connect to local MySQL server through socket >
Oct 23 16:08:21 testserver zmpkg[4130]: ERR [Error reconnecting to db: errstr:Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' >
Oct 23 16:08:21 testserver zmpkg.pl[4130]: Can't call method "prepare_cached" on an undefined value at /usr/share/perl5/vendor_perl/ZoneMinder/Config.pm line>
Oct 23 16:08:21 testserver zmpkg.pl[4130]: BEGIN failed--compilation aborted at /usr/share/perl5/vendor_perl/ZoneMinder/Config.pm line 147.
Oct 23 16:08:21 testserver zmpkg.pl[4130]: Compilation failed in require at /usr/share/perl5/vendor_perl/ZoneMinder.pm line 33.
Oct 23 16:08:21 testserver zmpkg.pl[4130]: BEGIN failed--compilation aborted at /usr/share/perl5/vendor_perl/ZoneMinder.pm line 33.
Oct 23 16:08:21 testserver zmpkg.pl[4130]: Compilation failed in require at /usr/bin/zmpkg.pl line 34.
Oct 23 16:08:21 testserver zmpkg.pl[4130]: BEGIN failed--compilation aborted at /usr/bin/zmpkg.pl line 34.
Oct 23 16:08:21 testserver systemd[1]: zoneminder.service: Control process exited, code=exited status=255
Oct 23 16:08:21 testserver systemd[1]: zoneminder.service: Failed with result 'exit-code'.
Oct 23 16:08:21 testserver systemd[1]: Failed to start ZoneMinder CCTV recording and security system.
-- Subject: Unit zoneminder.service has failed
You could try stating it explicitly in the Zoneminder config file. I’d have thought it would pick it up from my.cnf, just based on Linux experience.
whoop
Post by whoop »
Well it wasn't really straightforward figuring that out(at least not for me). But your suggestion seems to have helped me allot. Thank you.
I added a file named 03-custom.conf to /etc/zm/conf.d/
and added the following:
ZM_DB_HOST=localhost:/new/mysql/mysql.sock
I think this is the proper way to do it.
Now Zoneminder will start. Have not checked if everything is working though.
Thanks again.
Re: [SOLVED] Changing database location
I’m glad it helped.
Yes, popping that in the custom config file is best practice. It means it doesn’t get clobbered during upgrades later on.
