Multi Server
monkberry
Multi Server
Post by monkberry »
Hello all,
I've been working on a multi server install and have tested and working very well except for using the monitors under nodect. I've noticed that if I enable OPT_TRIGGERS under Options it does NOT start the zmtrigger.pl script and subsequently does not open port 6802. If I start the script manually, it opens port 6802 however it does not work with the cameras and I get this message a lot "Argument "motion" isn't numeric in pack at /usr/share/perl5/ZoneMinder/Memory.pm", where "motion" is what I called the script in the Axis camera that sends the notice to the server to start recording via tcp (6802).
Has anyone else run into this?
TIA, Peter
Re: Multi Server
I suspect this feature is not used by many.
Have you turn on run zmtrigger under options -> Servers ?
monkberry
Re: Multi Server
Post by monkberry »
Thanks for your reply. That is exactly what I did and what was needed. I didn't even look at the server options for such a thing but I google it and that was it!
I've yet to get any motion recording since I put this in place but I'm suspicious that the cameras themselves (Axis) are not sending notifications to more than one recipient because I do have the original configs in place on another server.
Thanks again for the reply!
Peter
