Hello all,
I've been working on a multi server install and have tested and working very well except for using the monitors under nodect. I've noticed that if I enable OPT_TRIGGERS under Options it does NOT start the zmtrigger.pl script and subsequently does not open port 6802. If I start the script manually, it opens port 6802 however it does not work with the cameras and I get this message a lot "Argument "motion" isn't numeric in pack at /usr/share/perl5/ZoneMinder/Memory.pm", where "motion" is what I called the script in the Axis camera that sends the notice to the server to start recording via tcp (6802).
Has anyone else run into this?
TIA, Peter
Multi Server
Re: Multi Server
I suspect this feature is not used by many.
Have you turn on run zmtrigger under options -> Servers ?
Re: Multi Server
Thanks for your reply. That is exactly what I did and what was needed. I didn't even look at the server options for such a thing but I google it and that was it!
I've yet to get any motion recording since I put this in place but I'm suspicious that the cameras themselves (Axis) are not sending notifications to more than one recipient because I do have the original configs in place on another server.
Thanks again for the reply!
Peter
Peter
