Error when running ./configure
seb3s
Post by seb3s »
Hi all,
It must be a dumb question, but I wasn't able to find a topic on it in the forum. I am trying to compile/build zoneminder on a debian/sarge.
When I run './configure' I get ':bad interpreter: Aucun fichier ou répertoire de ce type'.
OK, why not (some env var probably not correctly set, I don't know).
So I try 'sh ./configure', and I get './configure: line 19: syntax error near unexpected token 'elif'
I'm stuck here, any advice ?
Thanks,
Sebastien.
RedFlyer
Post by RedFlyer »
May be another dumb question ... do you have source and compiler installed for your sarge distro ?
Oliver
________
Meth rehab advice
seb3s
compiler
Post by seb3s »
I do have gcc/g++ installed.
What sources do I need ?
I currently know I need mysql-dev and ffmpeg-dev.
Sebastien.
