Face Detection not working
Support for the docker image maintained by dlandon
Minglarn
Post by Minglarn »
Hi!
Just downloaded and started dlandon latest image where OpenCV is updated to 4.5.0.
With OpenCV 4.3.0 face detection was working but with the latest image from github its kinda failing.
It does finds a face but does not send a push because it's does not match my filters?
What should I look for?
2020-12-06 22:46:26	zmesdetect_m17		67513	INF	discarding "face:John Doe" as it does not match your filters	image_manip.py	315
2020-12-06 22:46:26	zmesdetect_m17		67513	INF	Prediction string:[a] detected:person:95%	zm_detect.py	779
2020-12-06 22:46:10	zmesdetect_m17		67513	INF	labels found: ['person']	zm_detect.py	630
Docker:
docker run -d --name="Zoneminder"
--net="bridge"
--privileged="true"
-p 8443:443/tcp
-p 9001:9001/tcp
-p 6802:6802/tcp
-e TZ="Europe/Stockholm"
-e SHMEM="80%"
-e PUID="99"
-e PGID="100"
-e INSTALL_HOOK="1"
-e INSTALL_FACE="1"
-e INSTALL_TINY_YOLOV3="0"
-e INSTALL_YOLOV3="1"
-e INSTALL_TINY_YOLOV4="0"
-e INSTALL_YOLOV4="1"
-e MULTI_PORT_START="0"
-e MULTI_PORT_END="0"
 -v "/mnt/Zoneminder":"/config":rw -v "/mnt/Zoneminder/data":"/var/cache/zoneminder":rw
 dlandon/zoneminder
asker
Re: Face Detection not working
Post by asker »
This may be a result of the experiments I am doing with pyzm in master. Can you update your pyzm library with 0.2.7 and report? Also please post debug logs, not INF.
Please read before posting:
ES docs
zmNinja docs
Minglarn
Post by Minglarn »
Hi sorry for late response...
I did a full reinstall and it seems to work again..
