ERROR 1054 (42S22) at line 5: Unknown column 'Query_json' in 'where clause'
TheRoth
Post by TheRoth »
i update yesterday ZoneMinder and i have this problem... i don't know what can i do...
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
	LANGUAGE = (unset),
	LC_ALL = (unset),
	LC_CTYPE = "UTF-8",
	LANG = "fr_FR.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("fr_FR.UTF-8").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: Aucun fichier ou dossier de ce type
Setting up zoneminder (1.35.15~20201209.45-buster) ...
detected systemd
Detected db service is mariadb.service
Checking for db
Db exists.
Updating permissions for user zmuser@localhost
Initiating database upgrade to version 1.35.15 from version 1.35.14
Upgrading database to version 1.35.15
Loading config from DB 219 entries
Saving config to DB 219 entries
Upgrading DB to 1.35.15 from 1.35.14
Output:
Command 'mysql -hlocalhost -uzmuser -p'zmpass' zm < /usr/share/zoneminder/db/zm_update-1.35.15.sql' exited with status: 1
Freshening configuration in database
Migratings passwords, if any...
Done Updating
Job for zoneminder.service failed because the control process exited with error code.
See "systemctl status zoneminder.service" and "journalctl -xe" for details.
invoke-rc.d: initscript zoneminder, action "start" failed.
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
     Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
     Active: activating (auto-restart) (Result: exit-code) since Wed 2020-12-09 08:33:10 CET; 14ms ago
    Process: 3411 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=255/EXCEPTION)
dpkg: error processing package zoneminder (--configure):
 installed zoneminder package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
 zoneminder
E: Sub-process /usr/bin/dpkg returned an error code (1)
Re: ERROR 1054 (42S22) at line 5: Unknown column 'Query_json' in 'where clause'
Does it exist in your DB? If not, find where it would have been created and make it so.
TheRoth
Post by TheRoth »
i remove zone minder... and i install again... But new error :|
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
zoneminder : Depends: libdbd-mysql-perl but it is not going to be installed
Depends: libdevice-serialport-perl but it is not going to be installed
Depends: libsys-mmap-perl but it is not going to be installed
Depends: libdatetime-perl but it is not going to be installed
Depends: libsoap-wsdl-perl but it is not going to be installed
Depends: libio-socket-multicast-perl but it is not going to be installed
Depends: libsys-cpu-perl but it is not going to be installed
Depends: libsys-meminfo-perl but it is not going to be installed
Depends: libcrypt-eksblowfish-perl but it is not going to be installed
Depends: libdata-entropy-perl but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
TheRoth
Post by TheRoth »
Magic919 wrote: Wed Dec 09, 2020 3:04 pm Does it exist in your DB? If not, find where it would have been created and make it so.
i don't know... but my ZoneMinder was clean 2 years ago and i do nothing....
Sounds like you need to stay away from 1.35.x version and install the stable 1.34 instead.
Sounds like the db is not updated correctly. That change was in 1.33.14
mysql -u zmuser -p zm < /usr/share/zoneminder/db/zm_update-1.33.14.sql
Maybe try
sudo zmupdate.pl
Puydomois
Post by Puydomois »
I had the same problem :Re: ERROR 1054 (42S22) at line 5: Unknown column 'Query_json' in 'where clause'.
I found an error in database table : "Filters"
The column is named Query.
I rename it Query_json and all is now working .
If this can help you
Cordialement (Français)
