I am having no sound even though the test stream with vlc have sound with the stream and codecs detected as attached picture. I have enable the check box in Source > Storage for each camera.
I have 2 cameras from Besder and Anibiux, which represented as zmc_m5 and zmc_m6 . They are the standard China PTZ 1080p 2MP cameras with slightly different firmwares. I am running wired LAN for both of them.
ZM version 1.34.22 in Linux Mint 18.3 Cinnamon with Intel i5 4th Gen, 16GB RAM and 4TB internal HDD.
Please advice on how to proceed.
Sound issue
Sound issue
- Main and sub stream VLC codec info
- Main and Sub.png (63.11 KiB) Viewed 2339 times
- zm audio error
- zm audio error.png (206.11 KiB) Viewed 2339 times
Re: Sound issue
Make sure you disable store JPEG's and enable Video Writer. If you use the same Source Path as you used with VLC it should work.
Re: Sound issue
Mine settings are as picture. All are default except for pass-through. I turn off the save audio for now to stop the errors.
I am using morec. As I know these settings are needed.
- zm storage.png (20.89 KiB) Viewed 2294 times
Re: Sound issue
I can't tell in that pic if the save audio checkbox is checked but you said it was so let's just believe that.
You shouldn't be getting that error. Not sure what you can do about it other than give us access to your cameras to test/develop against.
Audio can be strange and it took a lot of work to get to this point where it works for every camera I have access to.
Re: Sound issue
Oh also, debug level 3 logs would be of use.
Re: Sound issue
In the picture, I have UnChecked it because the log errors.
Not sure what is debug level 3 but I normally turn all 4 logs at the top of the Logging page to Debug.
The camera is like the below. What I noticed from both my PTZ cameras from 2 different brands that their internal are generic and mostly a rebrand and some tweaking of the firmware .. one have PTZ Preset but the other does not.
https://www.aliexpress.com/item/4000263 ... hweb201603_
Re: Sound issue
You need to check the DEBUG_LOG checkbox further down.
Re: Sound issue
Level 3 debug on and the logs are the same .. I just blank out my camera's names.
I just hope there will be a solution in the future as this kind of cameras will be common in Asia since we get it cheaper than Aliexpress.
Zoneminder is already amazing for what it can do so far, even though there are lot for reading needed as it is a bit manual.
Thanks guys for the great work ! Loving the 10x 25x and 50x speed.
- zm debug level 3.png (113.58 KiB) Viewed 2241 times
Re: Sound issue
Strange .. I upgraded to Linux Mint 19.3 Cinnamon and I am recording sound now
without the above errors logged.
But its a shame I lost API after the upgrade and I have lost Net ONVIF a few updates ago.
