Fix timeline view bug that only shows 1 frame per event
leewells
Post by leewells »
Git patch against 1.34.22 to allow the timeline view to display multiple frames per event.
Once it had any frame, it was calling showEventData() instead of requestFrameData(). Now it will only call showEventData() if it has the event AND the frame.
0001-Fix-timeline-only-showing-1-event-per-frame.patch.txt
git patch to fix timeline 1 frame/event bug
(1.02 KiB) Downloaded 281 times
--Lee
leewells
Re: Fix timeline view bug that only shows 1 frame per event
Post by leewells »
Here's a new version of the patch that prevents an error message I saw in the logs when mouseing over mp4 captures.
--Lee
Improved patch to fix timeline bug
(1.05 KiB) Downloaded 297 times
I'll merge and release in 1.34.23
leewells
Post by leewells »
Awesome. Thanks
--Lee
