web interface not displaying properly
scimmiettarossa
Post by scimmiettarossa »
I installed versione 1.34.16 today, according to instructions
first problem: pointing the browser to localhost/zm, it found no page.... I had to put a symbolic link in /var/www/html, called "zm" pointing to /usr/share/zoneminder/www.. in this way the web interface shows up
but, second problem, that web interface is a bit weird: graphically s missing something (buttons, shapes etc),..
... and, anyway, it is not working: I am not able to add cameras, change settings etc.. all the buttons are ineffective
it seems a permission proble, but I'm not able to troubleshoot it properly.. is anyone willing to help me in this?
thanks
rosanna
Re: web interface not displaying properly
It helps if you say which instructions you followed.
Sounds like Apache not configured properly.
scimmiettarossa
this documentation:
https://zoneminder.readthedocs.io/en/la ... buntu.html
apache seems ok: all the other servers are working properly, both static and also a drupal installation with php and mysql
I tried to change the port for the zm server, but no luck
You haven’t properly configured the vhost for Apache to serve the ZM site or there’s a problem with that part of the config.
