Having problem with HikVision.pm
tafollaj
Post by tafollaj »
I am having trouble getting the Hikvision controls working and I was getting an command = undefined error. I ran perl HikVision.pm and got the following:
/usr/share/perl5/ZoneMinder/Control$ perl HikVision.pm
WARNING: ZoneMinder configuration file found but is not readable. Check file permissions on /etc/zm/zm.conf
WARNING: ZoneMinder configuration file found but is not readable. Check file permissions on /etc/zm/conf.d/zmcustom.conf
Use of uninitialized value $ZoneMinder::Config::Config{"ZM_DB_HOST"} in pattern match (m//) at /usr/share/perl5/ZoneMinder/Config.pm line 93.
Use of uninitialized value $ZoneMinder::Config::Config{"ZM_DB_HOST"} in concatenation (.) or string at /usr/share/perl5/ZoneMinder/Config.pm line 102.
Use of uninitialized value $ZoneMinder::Config::Config{"ZM_DB_NAME"} in concatenation (.) or string at /usr/share/perl5/ZoneMinder/Config.pm line 117.
DBI connect('database=;host=','',...) failed: Access denied for user 'pollosanto'@'localhost' (using password: NO) at /usr/share/perl5/ZoneMinder/Config.pm line 117.
Can't connect to db at /usr/share/perl5/ZoneMinder/Config.pm line 166.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder/Config.pm line 166.
Compilation failed in require at /usr/share/perl5/ZoneMinder/Logger.pm line 90.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder/Logger.pm line 90.
Compilation failed in require at HikVision.pm line 46.
BEGIN failed--compilation aborted at HikVision.pm line 46.
Does anyone know what the problem is here? Thanks.
Re: Having problem with HikVision.pm
check to make sure the permissions on /etc/zm/zm.conf are correct and match the Apache user !!
tafollaj wrote: Tue Mar 26, 2019 8:55 pm DBI connect('database=;host=','',...) failed: Access denied for user 'pollosanto'@'localhost' (using password: NO) at /usr/share/perl5/ZoneMinder/Config.pm line 117.
You can't call the zoneminder scripts or binaries from the command line as a normal user. They will only run as the root user or the web account user.
tafollaj
Post by tafollaj »
Thank you, I forgot to sudo. Regarding the problem I am having, this is the error I get when I try to use the controls. Am I missing a component in my install?
2019-03-27 14:21:45 zmcontrol 2301 FAT Can't load ZoneMinder::Control::Can't locate ZoneMinder/Control/.pm in @INC (you may need to install the ZoneMinder::Control:: module) (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.26.1 /usr/local/share/perl/5.26.1 /usr/lib/x86_64-linux-gnu/perl5/5.26 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.26 /usr/share/perl/5.26 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at /usr/share/perl/5.26/Module/Load.pm line 77.Can't locate ZoneMinder/Control/ in @INC (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.26.1 /usr/local/share/perl/5.26.1 /usr/lib/x86_64-linux-gnu/perl5/5.26 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.26 /usr/share/perl/5.26 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at /usr/share/perl/5.26/Module/Load.pm line 77.
tafollaj
Post by tafollaj »
Ok, got it working! The protocol wasn't set in the control definition for HikVision. Thanks for the help, much appreciated!
kobold81
Post by kobold81 »
what is the protocol please and where do I have to enter this?
JasonBorn
Post by JasonBorn »
kobold81 wrote: Thu Oct 31, 2019 11:26 pm what is the protocol please and where do I have to enter this?
Have you solved this problem? I'm at the moment on the same problem.
kobold81
Post by kobold81 »
sorry, was absent for some time.
I got it to work. in the "Control" tab, I used the name the hikvision camera gave me under the system tab of the camera as the "control device" and I selected "Hikvision" from "Control Type" and checked "Controllable" ." Control Address" ist username:password@ip address, e.g. gordon:password@192.168.1.12
