Docker ????
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
DVB Hardware
Docker ????
Post by DVB Hardware »
Is docker like flatpak
I have a spare drive and installed MX Linux just to play around with a new distro with Zoneminder
Just need some explanation so I can search correctly
Jimmy
burger
Re: Docker ????
Post by burger »
Docker is more like VMWare or Virtualbox. You run a program, and that program runs an OS (or multiple). Technically it's a container I think, but just think of it like virtualization.
MX would I guess follow the Debian instructions, where a repo is added. https://docs.docker.com/engine/install/debian/
Docker is great, but there's a learning curve. Get a book, and take notes. I've read Using Docker by Adrian Mouat. You will want to use docker-compose. I have notes here: https://steakwiki.com/index.php/Docker to give you an idea of what you are getting into.
As for Zoneminder, there are a couple of different docker Zoneminder images floating around. There is an official one linked in the Zoneminder github: https://github.com/ZoneMinder/zoneminde ... ils/docker
There is the dlandon one is waiting for a new developer: https://github.com/dlandon/zoneminder
https://github.com/QuantumObject/docker-zoneminder This one (unlike the other images) manages the DB separately, so mysql is its own container. That seems like the approach I would take.
See its dockerfile: https://github.com/QuantumObject/docker ... Dockerfile to get an idea of what the docker does when it starts up.
fastest way to test streams:
Re: Docker ????
I'd have a play with Docker, but not with ZM. You can already do ZM.
Have a look at IOTStack, perhaps.
DVB Hardware
Re: Docker ????
Thanks guy's , sounds like another learning curve. Too old for that now, will stick with mint
Jimmy
JoanPiper
Re: Docker ????
Post by JoanPiper »
I didn't notice at first that I had found the answer to my question))) Thank you guys!!
