DS-2DE3304W-DE PTZ
joeCarmon
DS-2DE3304W-DE PTZ
Post by joeCarmon »
Has anybody gotten the Hikvision DS-2DE3304W-DE to work for PTZ? I have been struggling with this for quite some time. The camera streams, but I am unable to control it.
joeCarmon
Re: DS-2DE3304W-DE PTZ
Post by joeCarmon »
Minor Update. I have set it for ONVIF, and think I am on the right track, but am getting http::80 (Bad hostname) in the error log for zmcontrol.
joeCarmon
Post by joeCarmon »
Bumping to see if anybody has any ideas.
security_dude
Post by security_dude »
I have it working on my machine. Make sure you are using this syntax under the control tab for the control address.
userid:password@server IP:port number
For example admin:passwrod@192.168.1.200:80
Did you create a script for it yet? The control device under the same tab should be your script name. Hope this helps.
does the Hikvision.pm work for these DS-2DE3304W-DE cameras?
Are the control commands correct in the control script?
security_dude
PM sent with modified script for you to try out.
Thanks! I am reviewing some of the different control scripts so this info helps!
kobold81
Post by kobold81 »
I have the DS-2DE2A404IW-DE3 working with the HikVision script provided by zoneminder.
Control Device: DS-2DE2A404IW-DE3
Control Address: admin:Password@10.10.4.21
Control Type: HikVision
Then click "Edit" next to Control Type.
Move: I clicked everything on
I entered Values at Pan, Tilt, zoom and clicked zoom on on.
I am still trying to figure out if a change in e.g. Pan steps dies anything ;-)
kingsize
Post by kingsize »
security_dude wrote: Wed Dec 11, 2019 1:21 pm I have it working on my machine. Make sure you are using this syntax under the control tab for the control address.
Thank you for posting. Can finally control my two from zm.
jcarmon
Post by jcarmon »
I am working on getting the same camera up and running, would you care to post your script?
Paranoid
Post by Paranoid »
Can you goto the following url on your camera and post the output?
http://<your camera>/ISAPI/PTZCtrl/channels/1/capabilities
walt
Post by walt »
I have the Hikvision DS-2DE2A404IW-DE3 and this is what I get:
<PTZChanelCap xmlns="http://www.hikvision.com/ver20/XMLSchema" version="2.0">
<AbsolutePanTiltPositionSpace>
<XRange>
<Min>0</Min>
<Max>3550</Max>
</XRange>
<YRange>
<Min>0</Min>
<Max>900</Max>
</YRange>
</AbsolutePanTiltPositionSpace>
<AbsoluteZoomPositionSpace>
<ZRange>
<Min>10</Min>
<Max>40</Max>
</ZRange>
</AbsoluteZoomPositionSpace>
<ContinuousPanTiltSpace>
<XRange>
<Min>-100</Min>
<Max>100</Max>
</XRange>
<YRange>
<Min>-100</Min>
<Max>100</Max>
</YRange>
</ContinuousPanTiltSpace>
<ContinuousZoomSpace>
<ZRange>
<Min>-100</Min>
<Max>100</Max>
</ZRange>
</ContinuousZoomSpace>
<maxPresetNum>300</maxPresetNum>
<maxPatrolNum>0</maxPatrolNum>
<maxPatternNum>0</maxPatternNum>
<maxLimitesNum>0</maxLimitesNum>
<maxTimeTaskNum>10</maxTimeTaskNum>
<controlProtocol opt="HIKVISION,PELCO-P,PELCO-D">PELCO-D</controlProtocol>
<controlAddress>0</controlAddress>
<PTZRs485Para xmlns="http://www.hikvision.com/ver20/XMLSchema" version="2.0">
<baudRate opt="2400,4800,9600,19200,38400">9600</baudRate>
<dataBits opt="5,6,7,8">8</dataBits>
<parityType opt="none,even,odd">none</parityType>
<stopBits opt="1,2">1</stopBits>
<flowCtrl opt="none,software,hardware">none</flowCtrl>
</PTZRs485Para>
<PresetNameCap xmlns="http://www.hikvision.com/ver20/XMLSchema" version="2.0">
<presetNameSupport>true</presetNameSupport>
<maxPresetNameLen max="20"/>
<specialNo opt="34,39,40,46,92,93,94"/>
</PresetNameCap>
<wiperStatusSupport>false</wiperStatusSupport>
<isSupportPosition3D>true</isSupportPosition3D>
<manualControlSpeed opt="compatible,pedestrian,nonMotorVehicle,motorVehicle,selfadaptive"/>
<isSpportPtzlimiteds>true</isSpportPtzlimiteds>
<oneKeyParkAction>true</oneKeyParkAction>
<oneKeyMenu>false</oneKeyMenu>
<ParkAction xmlns="http://www.hikvision.com/ver20/XMLSchema" version="2.0">
<enabled opt="true,false">false</enabled>
<Parktime min="5" max="720">5</Parktime>
<Action>
<ActionType opt="preset">preset</ActionType>
<ActionNum min="0" max="8">0</ActionNum>
</Action>
</ParkAction>
<TimeTaskList xmlns="http://www.hikvision.com/ver20/XMLSchema" version="2.0">
<TimeTaskBlock xmlns="http://www.hikvision.com/ver20/XMLSchema" version="2.0">
<dayOfWeek min="1" max="7">1</dayOfWeek>
<TimeTaskRange>
<TaskID min="0" max="10">0</TaskID>
<Task>
<TaskType opt="disable,preset,periodreboot,periodadjust">disable</TaskType>
<presetTaskNum min="0" max="8">0</presetTaskNum>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<TaskID min="0" max="10">1</TaskID>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<TaskID min="0" max="10">2</TaskID>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<TaskID min="0" max="10">3</TaskID>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<TaskID min="0" max="10">4</TaskID>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<TaskID min="0" max="10">5</TaskID>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<TaskID min="0" max="10">6</TaskID>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<TaskID min="0" max="10">7</TaskID>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<TaskID min="0" max="10">8</TaskID>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<TaskID min="0" max="10">9</TaskID>
<Task>
</Task>
</TimeTaskRange>
</TimeTaskBlock>
<dayOfWeek min="1" max="7">2</dayOfWeek>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
</TimeTaskBlock>
<dayOfWeek min="1" max="7">3</dayOfWeek>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
</TimeTaskBlock>
<dayOfWeek min="1" max="7">4</dayOfWeek>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
</TimeTaskBlock>
<dayOfWeek min="1" max="7">5</dayOfWeek>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
</TimeTaskBlock>
<dayOfWeek min="1" max="7">6</dayOfWeek>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
</TimeTaskBlock>
<dayOfWeek min="1" max="7">7</dayOfWeek>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
</TimeTaskBlock>
</TimeTaskList>
<PTZMotionTrack opt="true,false"/>
</PTZChanelCap>
