Modect no longer recording from IP camera
Zoltan
Post by Zoltan »
Recently upgraded to zoneminder 1.34.22 on Ubuntu 20.04 - and have now just done a full apt update/upgrade to make certain I have the latest install.
I've tried to search this forum for the 'Shared data...." log message below, but found no solution.
My Driveway camera, a HIK DS-2CD2045FWD-I 4mm IP camera configured as ffmpeg for modect RefImageBlend 12.5% and AlarmRefImageBlend for 6.25%
The camera has worked for many months, but now although it does fully monitor and does record until I cancel a forced alarm, it will not record when motion is detected.
My Logitech webcam in my office does still work with MODECT.
On this Driveway camera I have deleted the old Zones, tried withwalking past it with no Zones and also with 2 new zones. And of course restarted zoneminder numerous times.
No events are recorded, but the log file shows:
2021-01-17 18:43:10 zma_m5 5856 ERR Shared data not initialised by capture daemon for monitor Driveway zm_monitor.cpp 501
2021-01-17 18:43:10 zmdc 5814 ERR 'zma -m 5' exited abnormally, exit status 255 zmdc.pl
Please can I get some guidance on sorting this out.
Thanks in advance,
Zoltan
burger
Re: Modect no longer recording from IP camera
Post by burger »
Do you have any custom configurations that might have broken the upgrade? Did you make sure the DB is up to date with zmupdate.pl? When troubleshooting issues, there's a few common things that break. If it's not obvious, you can just wipe the install (purge) and restore from a db backup.
https://wiki.zoneminder.com/MySQL
That's what I might do in this situation, in case it's a corrupt install.
But, maybe someone else has a better idea, so if you want to wait you might get some other recommendations.
fastest way to test streams:
Zoltan
Post by Zoltan »
Hi Burger,
Thanks for the checklist.
I went through it, zmupdate.pl told me I was already latest so I looked at some MySQL stuff, and all seemed normal.
Also, the dirveway camera is/was working - it was just not recording events.
So I thought as hard as I should have, before my post.
Sure enough, the alarm was not being triggered so there were no 'events' to record.
I used presets and it seems that the defaults are non-sensical.
After reading the how to set up Zones wiki, I manually lowered the number of pixels required to trigger an event, and the system is now recording :-)
Big thanks for your input.
I will now attempt to sort out the logged errors I get, under a separate thread.
Regards,
Zoltan
burger
Post by burger »
Ah ok, I was under the impression that your setup was working w/Modect until you upgraded, but it sounds like that was not the case. So it's a PEBKAC error, but no worries. It's part of the learning curve. Zone configuration is tough. Some people use ZM ES. I mocord everything, and use software/hardware devices, as software detection is like all machine learning/AI, and it gets you 90-95% there, but no further. Always imperfect.
For reference the wiki article is here:
https://wiki.zoneminder.com/Understandi ... or_Dummies
Zoltan
Post by Zoltan »
"I was under the impression that your setup was working w/Modect until you upgraded, "
So was/am I. It is after I did the upgrade that I noticed it - and I don't fiddle with it so it is unlikely that it was a PEBKAC issue.
(Love the term PEBKAC [I use it quite a lot, even against myself :-) ] - amazing how few people even know it! )
Thanks for your help/comments.
Regards,
Zoltan
Andyrh
Post by Andyrh »
picnic
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
