Jan 21 2021 18:39:30.762996 [DBG 1] Object Recognition requested
Jan 21 2021 18:39:30.763094 [DBG 1] Stream info not found, looking at args...
Jan 21 2021 18:39:30.763430 [DBG 1] get_file returned: ./images/9d77d499-35a2-4a1d-bf13-a1756ab30839.jpg
192.168.17.60 - - [21/Jan/2021 18:39:30] "POST /api/v1/detect/object?type=object&delete=True HTTP/1.1" 500 -
Error on request:
Traceback (most recent call last):
File "/usr/local/lib/python3.8/dist-packages/werkzeug/serving.py", line 323, in run_wsgi
execute(self.server.app)
File "/usr/local/lib/python3.8/dist-packages/werkzeug/serving.py", line 312, in execute
application_iter = app(environ, start_response)
File "/usr/local/lib/python3.8/dist-packages/flask/app.py", line 2464, in __call__
return self.wsgi_app(environ, start_response)
File "/usr/local/lib/python3.8/dist-packages/flask/app.py", line 2450, in wsgi_app
response = self.handle_exception(e)
File "/usr/local/lib/python3.8/dist-packages/flask_restful/__init__.py", line 272, in error_router
return original_handler(e)
File "/usr/local/lib/python3.8/dist-packages/flask/app.py", line 1867, in handle_exception
reraise(exc_type, exc_value, tb)
File "/usr/local/lib/python3.8/dist-packages/flask/_compat.py", line 38, in reraise
raise value.with_traceback(tb)
File "/usr/local/lib/python3.8/dist-packages/flask/app.py", line 2447, in wsgi_app
response = self.full_dispatch_request()
File "/usr/local/lib/python3.8/dist-packages/flask/app.py", line 1952, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/usr/local/lib/python3.8/dist-packages/flask/app.py", line 1821, in handle_user_exception
File "/usr/local/lib/python3.8/dist-packages/flask/app.py", line 1950, in full_dispatch_request
rv = self.dispatch_request()
File "/usr/local/lib/python3.8/dist-packages/flask/app.py", line 1936, in dispatch_request
return self.view_functions[rule.endpoint](**req.view_args)
File "/usr/local/lib/python3.8/dist-packages/flask_restful/__init__.py", line 468, in wrapper
resp = resource(*args, **kwargs)
File "/usr/local/lib/python3.8/dist-packages/flask/views.py", line 89, in view
return self.dispatch_request(*args, **kwargs)
File "/usr/local/lib/python3.8/dist-packages/flask_restful/__init__.py", line 583, in dispatch_request
resp = meth(*args, **kwargs)
File "/usr/local/lib/python3.8/dist-packages/flask_jwt_extended/view_decorators.py", line 108, in wrapper
return fn(*args, **kwargs)
File "/home/loren/mlapi/mlapi.py", line 153, in post
g.log.Debug (1, f'Calling detect streams with {stream} and {stream_options} and ml_overrides={ml_overrides} ml_options={ml_options}')
UnboundLocalError: local variable 'ml_overrides' referenced before assignment
Thank you!
