Cannot use "8 hour" or view "all events"
frozenfood
Post by frozenfood »
ZM has been working OK for me for the past 3 weeks, but now I cannot view the "8 hour" or "all events" as the website crashes. it is possible to view 1 hr at a time by changing the time text to no more than 1-2 hours but anything more than that, it crashes. is it running out of memory? I have 16GB in the server
Re: Cannot use "8 hour" or view "all events"
Have you seen the bit about setting buffers to 2?
frozenfood
what buffers are you refering to?
It has worked this morning looking at 8 hours of night, so I can only conclude it is the large ammount of trigger events causing the fault.
viewtopic.php?f=42&t=29949#p119909
The buffers for the cams.
frozenfood
i'm not sure what buffer you are refering to, so I set the only thing with buffer in the text to "2" and it still does not work
now clicking on "8 hours" lead to a white website with no infomation what so ever. is there any other settings that require adjustment?
Dunno.
Quite a few problems with this build - but there's a newer one out today you should try.
Or go back to a release (1.34.x) version.
frozenfood
is there a reliable release? or should I just go back to shinobi?
I'm finding loads of other things that dont work, like the "download video" to a 1hr time it says it will be 4.6GB, doesnt ask me which stream it is going to download and then gives me a 450MB download, which is only 1 stream and only a fraction of the video, and it doesnt have the timestamp added, which makes the whole thing worthless if I wanted to get a video that wasnt picked up on a event, that was the prime reason I went to mocord.
Stick to 1.34 releases. This is the development branch.
