I have a filter that I have defined to delete old events. It's not the only filter and I now have the filters working correctly. However when zmfilter tries to run this filter automatically I get errors in the log file:
Use of uninitialized value in localtime at /usr/local/bin/zmfilter.pl line 141.
Looking at zmfilter.pl, line 141 is
return( localtime(UnixDate( $date_str, '%s' )) );
I take it that this implies that $date_str is unset.
What am I doing wrong?
Russell.
zmfilter.pl errors running filter
Re: zmfilter.pl errors running filter
ahaaaaaaaaa......
so iam not crazy. :)
i get same error sinse 0.9.16...
i still dont have any idea how to fix it..
http://www.zoneminder.com/forum_general ... 116e2a48ba
http://www.zoneminder.com/forum_general ... afd52d9275
and this problem has came sinse this..
http://www.zoneminder.com/forum_general ... f75d453fe2
- zoneminder
- Site Admin
- Contact:
Did you try my last suggestion Fernando? Did it make any difference?
Phil,
Phil,
mmm i did't get your suggestion!
what was it..?
iam interesting in get Ross Melin mandrake live cd. so i can test a diferent scenario.
http://www.zoneminder.com/forum_install ... 8c8910996b
do you have it? you will put it on the web?
what was it..?
- zoneminder
- Site Admin
- Contact:
He is posting it to me. Once I get it I will put it up. We did try once before but I couldn't get the ISO off the CD properly so this is our second go.
The suggestion I made about your filter problems (a couple of weeks ago) was just
"Can you change your filter to use '-1 hour' instead of 'last hour' and see if that makes any difference."
Did you try that?
Phil,
Did you try that?
Phil,
yes... semms to run ok. i cant.. use -1 hour works..
were you tell this? how did i miss that?
well... i will tell you if some new bug is found.
I changed the filter from using last day to using -1 day and it now works. Thanks Phil.
What puzzles me though is that the filter works fine when run via the web interface but not when run automatically. i guess this is the difference between the Perl and PHP date formats.
Russell.
Russell.
- zoneminder
- Site Admin
- Contact:
Yes Russell. You are correct. The web pages use strtotime to parse date/times while the perl functions use UnixDate from the Date::Manip package. They are quite similar but obviously have some subtle differences. I've made a note to see if I can put a more useful error message into zmfilter to indicate this.
Phil,
Phil,
