Add event columns for easier filter creation
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
dthomas0424
Post by dthomas0424 »
I have been using other windows based security camera systems and recently switched to ZM. I would like a way to filter events based on the length of time that they have been in existence. If this was available I could create a filter to (for example) delete any events for a certain monitor or storage area that are greater than 365 days or greater than 12 months or greater than well.......any given time frame. I have found that so far I can only specify a certain calendar date/time to do this.
Thank you.
burger
Re: Add event columns for easier filter creation
Post by burger »
dthomas0424 wrote: Fri Feb 26, 2021 3:50 pm I would like a way to filter events based on the length of time that they have been in existence.
See https://zoneminder.readthedocs.io/en/la ... te-strings
fastest way to test streams:
