I tried installing to try it out. After installation I get the error "User Authentication is not turned on. You cannot log in." How do I turn authentication on?
Thanks,
1.35.20 Ubuntu 20.04 "User Authentication is not turned on. You cannot log in."
Re: 1.35.20 Ubuntu 20.04 "User Authentication is not turned on. You cannot log in."
This is a development version...there may still be a problem getting access to the database.
So, try this:
viewtopic.php?f=42&t=30563#p120473
So, try this:
- bkjaya1952
No it is not working . It seems there is a problem in mysql configuration in the latest version of zoneminder master .dougmccrary wrote: ↑Tue Mar 09, 2021 1:21 am This is a development version...there may still be a problem getting access to the database.
So, try this:
- bkjaya1952
The problem seems to be fixed in the latest zoneminder master realesed today.But ,there is a problem in creating USB camara monitors
I am also having problems with local USB cameras not streaming but seem to be capturing. Also my network cameras that use "Remote" as the Source Type are showing the same behavior.
latest should fix issues with non-ffmpeg monitor adding.
- bkjaya1952
I installed 1.36.5 on Ubuntu 18.04.5 and am getting the same "User authentication is not turned on. You cannot log in." Non of the suggestions appear to work - can't login so cannot modify config, redirection is imposed on any edit of url etc. The comments above appear to indicate it was fixed in the master a few months back so expected would be fixed in 1.36. I have since un installed wondering if another iconnor ppa might be more successful. Any help would be much appreciated
Mike
Mike
