nph-zms not open
Cramac1
nph-zms not open
Post by Cramac1 »
Hello.
after some time, arbitrary, the online video stops working, loads the page with the video (nph-zms) for a long time and then gives an error, the resource is not available. Sometimes restarting the Apache helps, now only restarting the zoneminder has helped.
after reboot, it continues to work normally. Found nothing in the logs, or looked in the wrong place.
Which way to go?
zm ver -1.35.16
Re: nph-zms not open
We're up to 1.35.20
But, how's your cpu usage?
Sometimes mine gets a little behind and it recovers on its own (gives up on older stuff, and more or less restarts itself, I think).
Cramac1
Post by Cramac1 »
Снимок экрана 2021-03-12 в 08.40.34.png (284.51 KiB) Viewed 1690 times
CPU - AMD Ryzen 7 1700X
12 cameras in total. Writes as is (H264 camera Passthrough). recording only
