I am lost in the configuration of zmeventnotification
titof2375
Post by titof2375 »
Hello and sorry for my English, as the title says I am lost in the configuration of I am lost in the configuration of zmeventnotification between the tutorials which are not up to date and the changes made in zmeventnotification. I tried to go through the https://github.com/pliablepixels/zmeventnotification
My, I don't understand a thing, if a charitable soul can help me.
tsp84
Re: I am lost in the configuration of zmeventnotification
Post by tsp84 »
Do you have a GPU or a TPU for object detection? This will change how its set up.
What don't you understand? What is the problem?
Have you installed the ES? Have you read the docs?
I installed everything needed for ES and GPU obj Det using the readthedocs docs.
titof2375
Post by titof2375 »
how to say, my system does not detect any object and thus no notification in mqtt, I think that I have badly configured a parameter. My what I do not know precisely and I can not find a tutorial to install correctly with the last update.
I am french and I go through google translate.
sudo -u www-data /var/lib/zmeventnotification/bin/zm_detect.py  -c /etc/zm/objectconfig.ini -e 24524
Make sure the event number (24524) matches an alarm on your system. What does it do?
Check logs also.
titof2375
Post by titof2375 »
nothing happens
Ok.
And the logs? Should be some zmesdetect***.log.
egrep 'FAT|ERR|WAR' /var/log/zm/zmes*.log
Also please test
sudo -u www-data /var/lib/zmeventnotification/bin/zm_event_start.sh
Add the eventID and MonitorID.
titof2375
Post by titof2375 »
zoneminder erreur1.PNG (65.31 KiB) Viewed 22714 times
Magic919 wrote: Mon Mar 15, 2021 1:20 pm Ok.
titof2375
Post by titof2375 »
Magic919 wrote: Mon Mar 15, 2021 1:30 pm Also please test
zoneminder 5666.PNG (8.09 KiB) Viewed 22714 times
Ok. The FAT error is FATAL, so it won't work.
It's throwing an exception and I'm not clever enough to know why.
Might be worth testing your config with this.
sudo /usr/bin/zmeventnotification.pl --check-config
The author @asker might appear here if we are lucky.
titof2375
Post by titof2375 »
Magic919 wrote: Mon Mar 15, 2021 6:09 pm Ok. The FAT error is FATAL, so it won't work.
That Picture URL is meant to point to your Zoneminder instance.
titof2375
Post by titof2375 »
Magic919 wrote: Tue Mar 16, 2021 8:16 am That Picture URL is meant to point to your Zoneminder instance.
hi, are you talking about what's surrounded.
After which it is in which file suddenly?
In secrets.ini. It's the first one, but you might as well check the other ones too.
/etc/zm/secrets.ini:ZMES_PICTURE_URL=http://ZM_HOST/zm/index.php?view=image&eid=EVENTID&fid=alarm&width=600
/etc/zm/secrets.ini:ZM_PORTAL=http://ZM_HOST/zm
/etc/zm/secrets.ini:ZM_API_PORTAL=http://ZM_HOST/zm/api
ZM_HOST change to match your server.
titof2375
Post by titof2375 »
pas compris.PNG (50 KiB) Viewed 22643 times
I don't understand how to do it
