New Install v1.34.23
Airman Clench
Post by Airman Clench »
My first install ever. I used the Conner ppa and I surprised myself by having no issues.
I can bring up the ZM GUI showing my one camera with red indicator, source is orange, and shows no video, "Monitoring is not active"
Error log says
  • Storage::disk_usage_percent: path /zm does not exist
  • Socket /run/zm/zms-866743s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.
  • Can't getaddrinfo(http://192.168.0.176 port 80): Name or service not known
  • 'zmc -m 1' exited abnormally, exit status 255
  • Memory map file '/dev/shm/zm.mmap.1' does not exist in zmMemAttach. zmc might not be running. zmwatch.pl
  • zma -m 1' exited abnormally, exit status 255 zmdc.pl
  • Can't open memory map file /dev/shm/zm.mmap.1, probably not enough space free: No such file or directory
I have read in a cople places that ZMS_path may have to be tweaked, but I am not sure where and what to.
Any help, please?
Airman Clench
Re: New Install v1.34.23
Answer is change source>source>hostname to IP only, no http://
so pictures are working.
Now just two errors in log,
web_php 414885 ERR Path /zm does not exist. /usr/share/zoneminder/www/includes/Storage.php 112
web_php 414885 WAR Storage::disk_usage_percent: path /zm does not exist /usr/share/zoneminder/www/includes/Storage.php 74
where do I set the zm path?
Thanks,
Hans
burger
Post by burger »
Did you set a custom storage area or are you using the default? The default is at /var/cache/zoneminder/events. Do you see videos there? If you set a custom storage area, did you set it up properly? See: https://wiki.zoneminder.com/Using_a_ded ... Hard_Drive
What is not working? You haven't specified an actual error outside of the logs.
fastest way to test streams:
