Zoneminder master 1.35.26~20210417163214-focal , modect, - not saving events [ Solved ]
bkjaya1952
Post by bkjaya1952 »
I have tested The Zoneminder master 1.35.26~20210417163214-focal released today with aUSB camera monitor.
It has been observed that the modect is not working .
Screenshot from 2021-04-18 13-54-00.png (231.04 KiB) Viewed 2926 times
The error logs are appended below.
Screenshot from 2021-04-18 13-47-30.png (323.49 KiB) Viewed 2926 times
Screenshot from 2021-04-18 23-09-42.png (415.95 KiB) Viewed 2858 times
Re: Zoneminder master 1.35.26~20210417163214-focal , modect, mocord- not saving events
The error message is pretty clear. It can't open the directory to put the files in. Could be out of disk space, permissions, etc.
phgerin
Post by phgerin »
I have the same problem since the last 2 builds. Nothing has changed in my config, plenty of disk space available. Morecord works for me but not Modect. Error message :
Socket /run/zm/zms-613313s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.
bkjaya1952
phgerin wrote: Sun Apr 18, 2021 5:10 pm I have the same problem since the last 2 builds. Nothing has changed in my config, plenty of disk space available. Morecord works for me but not Modect. Error message :
Yes Morecord works . Only modect is not working
bkjaya1952
Re: Zoneminder master 1.35.26~20210417163214-focal , modect, - not saving events
Still the modect problem is there in the Zoneminder-master latest 1.35.26~20210419131933-focal & Zoneminder-master latest 1.35.26~20210419131933-bionic
They are working fine for me. Please double check. Send logs
bkjaya1952
iconnor wrote: Mon Apr 19, 2021 7:33 pm They are working fine for me. Please double check. Send logs
Thank you very much Sir ! :D :D
I have tested the latest Zoneminder master latest version 1.35.26~20210419170703-focal released today . The modect is OK !
Screenshot from 2021-04-20 12-55-05.png (226.71 KiB) Viewed 2800 times
