color - b/w image problem with 1 camera
visiperl
Post by visiperl »
Hi all,
I have 6 of the same cameras. 30LED round gold colored with wired and wireless connections. All are working wonderful except for the one on /dev/video(0)2 . It's showing up in what appears to be b/w. I've verified all the settings and they all match. Below are links to two pictures, one correct and the one that is showing b/w.
http://www.helpconsulting.net/images/capture1.gif
http://www.helpconsulting.net/images/capture2.gif
ZM version 1.21.0
AMD Sempron 2100 w/512Megs DDR
160gig HD
Hard drive config:
3gig /
1.6gig swap
remainder as /var
I've reduced the buffers also for each camera.
Thanks,
visiperl
jameswilson
Post by jameswilson »
have you confirmed this camera is outputting colour as it looks like the image is very noisy and maybe due to what it thinks i spoor light. Take the bnc/phone out of zm and put it on a monitor and see what you get
Also could do with a bit more info about your capture cards and what is on what port etc
James
visiperl
update
Post by visiperl »
I just swapped the cables between video(0)1 and video(0)2 and the b/w problem appears to be a port issue on the card.
Has anyone seen this before?
thanks,
visiperl
jameswilson
I have on a osprey card i had, usually means linux has not autodetected your card fully and will need a little help. What cards you using
and if you use the same port on another card is the issue the same (assuming your cards are identical) just to prove weather it is a card issue
James
visiperl
Post by visiperl »
Hi James,
You're exactly correct. The 3rd port down on the identical card beside it has the same problem. What config files should I edit to make sure it's getting the right card. I believe you stated in another thread about card=77 or something (going from memory).
Thanks,
visiperl
jameswilson
i did, but i depends on your card. what is it or what are they.
got a pic i could lokk at. Others here will ask for lspc output or something but im not that good yet
James (needs pics lol)
visiperl
Post by visiperl »
at this point I don't. I will get my digital camera and come back and shoot a pic of it and post.
thanks for your help. I feel like I'm finally making some progess here.
cheers!
visiperl
jameswilson
anytime mate hopefully we can sort it
James
visiperl
here's the pic
Post by visiperl »
Here's the picture of the cards I'm using;
http://www.helpconsulting.net/images/4portvideo.jpg
Thanks,
ken
jameswilson
thats definetly at a 77
open your modprobe.conf (in /etc)
add
"options bttv card=77"
save it and reboot and you should be away.
Out of interest if i dont enter 77 i get nothing (are you using ntsc cameras)
James
visiperl
Post by visiperl »
yes, NTSC.
Thanks for the help. I'm in another state, but I'll try to remap the router for ssh to it and make the change reboot and see what happens.
Will keep you posted.
Cheers!
Ken
jameswilson
yeah let me know how you ge on but im 99% sure that will sort you out.
James (from the uk on PAL)
