no emails for alarms after data restore and upgrade
nonwo1
Post by nonwo1 »
Hi All,
I'm running version 1.36.1 under a Docker in Unraid. I had a corruption issue in the prior release, and I restored all of the data from the last backup. I'm able to trigger alarms and see them in the alarms triggered for the hour. But I cannot get emails. Did something change in 1.36.1? Or did restoring the data corrupt the emails? I've attached a screenshot of my email settings.
Mark
bkjaya1952
Re: no emails for alarms after data restore and upgrade
Post by bkjaya1952 »
This question is relevant to the Docker section at viewforum.php?f=41
clangren
Post by clangren »
Also note from the main Announcements post by iconnor:
Filters
- Moved event email options from global config to per Filter
nonwo1
Post by nonwo1 »
Under filters, I see the email details of all matches checked. I think it is setup correctly.
Manually run the filter to ensure it matches as a first step.
nonwo1
Post by nonwo1 »
I am not sure why I am having difficulty with this. This is how I have my alarm events setup under filters. I can see in the log when I trigger an alarm. But nothing goes out. Then I execute this filter, and nothing happens. I see the log state it is sending an email. Thoughts?
bkjaya1952
Please try the docker image at the following link .
https://hub.docker.com/repository/docke ... 7.4-mysql8
