Yes. Got the same.. thx for the headsup!
Seems to be some issues in regards to versioning.
shows 1.36.3
apt policy zoneminder
zoneminder:
Installed: 1.36.3-buster
Candidate: 1.36.3-buster
Version table:
*** 1.36.3-buster 500
500 https://zmrepo.zoneminder.com/debian/release-1.36 buster/ Packages
100 /var/lib/dpkg/status
1.36.2-buster 500
1.36.0-buster1 500
Initiating database upgrade to version 1.37.0 from version 1.36.0
Do you wish to take a backup of your database prior to upgrading?
This may result in a large file in /var/tmp/zm if you have a lot of events.
Press 'y' for a backup or 'n' to continue : y
Creating backup to /var/tmp/zm/zm-1.36.0.dump. This may take several minutes.
Database successfully backed up to /var/tmp/zm/zm-1.36.0.dump, proceeding to upgrade.
