Hi
I might be missing something obvious...
I am trying to debug my problems of 1.36 on a new install on RPi 4 (viewtopic.php?f=43&t=31003)
I found out that the capture process can be run on the CLI
I tried
`zmc -r rtsp -H uname:pw@192.168.xxx.xxx -P 554 -p stream1`
However, that returns with
`zmc: invalid option -- 'r'`
That is surprising.
Any idea how I can test the zmc process?
Best
ZMC CLI client missing option 'r'
Re: ZMC CLI client missing option 'r'
Um.. there has never been an r option.
Typically (there are other more modern ways that I am unfamiliar with) to do this I do:
sudo su -s/bin/bash -c"zmc -m 1" www-data
replace the 1 with whatever id of the monitor.
But never implemented in code..
I don't personally feel that this is useful... create the db entry, then run it with -m 1 as I advised above in 2021.
What I will do is fix the man page entry. I might be inclined to add a -u URL option, as that, and -d=/dev/video0 are about the only two useful ways to do this.
Unless someone else would like to step up and provide the code.
