Hi!
I have an issue that I couldn't solve.
As you can see in the image enclosed only 6 cameras goes online. I found only topics about problems with "Montage" viev of more than 6 cameras but in my case 7th camera simply doesnt go online. If I make one of those working offline, another one for example "Plac7" goes online but not more than 6 devices in one time.
Looks like limit of online devices? Something wrong in config?
Best regards!
Online devices limit
- Bez tytułu.jpg (185.68 KiB) Viewed 2724 times
Re: Online devices limit
Montage viewing of 6 cameras is an unrelated issue. That is only for a client viewing the cameras, not the recording of them. What are your system specs? This scenario looks like you don't have enough CPU / RAM to run 7 cameras. Is this an ARM board? If that is the case, you can try lowering the FPS / resolution on the cameras, or upgrading the hardware.
fastest way to test streams:
If you are using Firefox there is a browser fix:
Enter about:config in the address bar
scroll down to
browser.cache.check_doc_frequency 3
change the 3 to a 1
browser.cache.disk.enable True -> False
network.http.max-connections-per-server -> put a value of 100
network.http.max-persistent-connections-per-proxy -> 100 again
network.http.max-persistent-connections-per-server -> 100 again
scroll down to
change the 3 to a 1
