CPU util
Re: CPU util
More information is needed.
1. Resolution of the the cameras
2. FPS
3. Are you using passthrough
4. Function (Record, Modect...)
5. Dedicated system?
6. exact version
7. OS
8. Other interesting things
You question is kind of like "My car won't start" Most people will say check the battery, but after more information is given the solution is don't use a Ford key in a Chevy.
2. FPS
6. exact version
7. OS
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
Re: CPU util
1. 1920 1080
2. 15
4. record
6. 1 34 26
7. ubuntu server 20
2. 15
4. record
6. 1 34 26
7. ubuntu server 20
Re: CPU util
26 cameras over IP at 15fps 1080p is a pretty impressive load; it's like 6-8 times the load on my machine (12 IP cams, 6fps 720p on a 4-core i7 with 32G of ram, and my load average idles at 5 in modect, up around 8 in Montage Review).
Putting all of that on one machine is going to require some horsepower.
Re: CPU util
agreed Baylink, I have 8 cameras at 6fps 720P. On a Quad X5650 with 12GB ram in Mocord and it averages about 2
Maybe I could up the resolution a step based on your figures funyfizik, as now we have passthrough it more than halved the load from 1.34
Re: CPU util
It seems worth pointing out here that the general opinion about load on a linux box on current-generation Intel Hardware is that you can afford about two processes per core before things start to get out of hand.
So on my quad core i7, I can afford a load average of 8 as a reasonable standard number.
