Event/recording breaks with: "zmwatch: Restarting capture daemon xxxxx"
sandnabba
Post by sandnabba »
Hi everyone!
Just trying out Zoneminder as a replacement for the now discontinued Unifi Video. Everything seems to work fine, except that some events, sometimes just breaks in the middle of a recording (and the next minute of the event is lost).
Here is an example:
As you can see in the screenshot, the video is still in an alarm state, when it suddenly stops.
Here is the log for this particular event:
"2021-08-19 23:05:26",zmwatch,,16479,ERR,"Memory map file '/dev/shm/zm.mmap.1' does not exist in zmMemAttach.  zmc might not be running.",zmwatch.pl,'-
"2021-08-19 23:05:25",zmdc,,16389,INF,"Starting pending process, zmc -m 1",zmdc.pl,'-
"2021-08-19 23:05:23",zmdc,,16389,INF,"'zmc -m 1' exited normally",zmdc.pl,'-
"2021-08-19 23:05:15",zmdc,,16389,INF,"'zmc -m 1' sending stop to pid 158134 at 21/08/19 23:05:15",zmdc.pl,'-
"2021-08-19 23:05:13",zmwatch,,16479,WAR,"Restarting capture daemon for Garageuppfart, time since last capture 48 seconds (1629407113-1629407065)",zmwatch.pl,'-
"2021-08-19 23:05:12",zmc_m1,,158137,INF,"Garageuppfart: 422 - Gone back into alarm state",zm_monitor.cpp,2127
"2021-08-19 23:05:12",zmc_m1,,158137,INF,"Garageuppfart: 422 - Alarmed frame while in alert state. Consecutive alarmed frames left to return to alarm state: 000",zm_monitor.cpp,2124
"2021-08-19 23:05:11",zmc_m1,,158137,INF,"Garageuppfart: 400 - Analysing at 2.33 fps from 399 - 299=100 / 1629407111.559795 - 1629407068.570872 = 42.988923",zm_monitor.cpp,1704
"2021-08-19 23:05:08",zmc_m1,,158134,INF,"Garageuppfart: 800 - Capturing at 10.00 fps, capturing bandwidth 891893bytes/sec",zm_monitor.cpp,1663
"2021-08-19 23:04:58",zmc_m1,,158134,INF,"Garageuppfart: 700 - Capturing at 11.27 fps, capturing bandwidth 1055288bytes/sec",zm_monitor.cpp,1663
"2021-08-19 23:04:57",zmc_m1,,158137,INF,"Garageuppfart: 367 - Gone into alert state",zm_monitor.cpp,2144
There is no significant load on the host. Averages ~1.2 on a 4-core CPU, running ZM 1.36.5 in the "Easy to use Docker image".
I'm very new to the ZM platform, so any help troubleshooting this is much appreciated.
// Emil
Re: Event/recording breaks with: "zmwatch: Restarting capture daemon xxxxx"
Honestly looks like a bug to me.
zmwatch is a watchdog that looks for locked up processes and restarts them. It defaults to 45 seconds, but you can change this in options->System->WATCH_MAX_DELAY
We can clearly see in your logs that zmc is responding and doing things less than 45 seconds ago.
So I am tempted to tell you for now to increase that 45 to something significantly larger and I will have to think about what is going on.
Another thing to do is turn on debug logging.
sandnabba
Post by sandnabba »
Thanks iconnor!
I'll try WATCH_MAX_DELAY 300 for now to see how it behaves.
I grepped for "zmwatch" in the log, and it seems like it's restarting quite often actually:
Aug 20 17:28:08 1ea317d65ea5 zmwatch[16479]: INF [Restarting capture daemon for Garageuppfart, shared data not valid]
Aug 20 17:29:14 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 46 seconds (1629473352-1629473306)]
Aug 20 17:29:32 1ea317d65ea5 zmwatch[16479]: ERR [Memory map file '/dev/shm/zm.mmap.1' does not exist in zmMemAttach.  zmc might not be running.]
Aug 20 17:29:33 1ea317d65ea5 zmwatch[16479]: INF [Restarting capture daemon for Garageuppfart, shared data not valid]
Aug 20 17:30:38 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 46 seconds (1629473438-1629473392)]
Aug 20 17:31:01 1ea317d65ea5 zmwatch[16479]: ERR [Memory map file '/dev/shm/zm.mmap.1' does not exist in zmMemAttach.  zmc might not be running.]
Aug 20 17:31:02 1ea317d65ea5 zmwatch[16479]: INF [Restarting capture daemon for Garageuppfart, shared data not valid]
Aug 20 17:32:46 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 50 seconds (1629473566-1629473516)]
Aug 20 17:33:01 1ea317d65ea5 zmwatch[16479]: ERR [Memory map file '/dev/shm/zm.mmap.1' does not exist in zmMemAttach.  zmc might not be running.]
Aug 20 17:33:01 1ea317d65ea5 zmwatch[16479]: INF [Restarting capture daemon for Garageuppfart, shared data not valid]
Aug 20 17:36:59 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 48 seconds (1629473818-1629473770)]
Aug 20 17:37:11 1ea317d65ea5 zmwatch[16479]: ERR [Memory map file '/dev/shm/zm.mmap.1' does not exist in zmMemAttach.  zmc might not be running.]
Aug 20 17:37:11 1ea317d65ea5 zmwatch[16479]: INF [Restarting capture daemon for Garageuppfart, shared data not valid]
Aug 20 17:46:15 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 49 seconds (1629474375-1629474326)]
Aug 20 17:47:30 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 46 seconds (1629474449-1629474403)]
Aug 20 17:47:50 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 67 seconds (1629474470-1629474403)]
Aug 20 17:48:01 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 78 seconds (1629474481-1629474403)]
Aug 20 17:48:11 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 88 seconds (1629474491-1629474403)]
Aug 20 17:50:52 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 49 seconds (1629474651-1629474602)]
Aug 20 17:51:08 1ea317d65ea5 zmwatch[16479]: ERR [Memory map file '/dev/shm/zm.mmap.1' does not exist in zmMemAttach.  zmc might not be running.]
Aug 20 17:51:08 1ea317d65ea5 zmwatch[16479]: INF [Restarting capture daemon for Garageuppfart, shared data not valid]
Aug 20 17:56:09 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 54 seconds (1629474969-1629474915)]
Aug 20 17:58:23 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 46 seconds (1629475102-1629475056)]
Aug 20 17:58:34 1ea317d65ea5 zmwatch[16479]: ERR [Memory map file '/dev/shm/zm.mmap.1' does not exist in zmMemAttach.  zmc might not be running.]
Aug 20 17:58:34 1ea317d65ea5 zmwatch[16479]: INF [Restarting capture daemon for Garageuppfart, shared data not valid]
Aug 20 17:58:44 1ea317d65ea5 zmwatch[16479]: ERR [Memory map file '/dev/shm/zm.mmap.1' does not exist in zmMemAttach.  zmc might not be running.]
Aug 20 17:58:45 1ea317d65ea5 zmwatch[16479]: INF [Restarting capture daemon for Garageuppfart, shared data not valid]
Aug 20 18:03:25 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 53 seconds (1629475405-1629475352)]
Aug 20 18:03:43 1ea317d65ea5 zmwatch[16479]: ERR [Memory map file '/dev/shm/zm.mmap.1' does not exist in zmMemAttach.  zmc might not be running.]
Aug 20 18:03:43 1ea317d65ea5 zmwatch[16479]: INF [Restarting capture daemon for Garageuppfart, shared data not valid]
Aug 20 18:09:46 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 46 seconds (1629475785-1629475739)]
Aug 20 18:13:10 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 46 seconds (1629475989-1629475943)]
Aug 20 18:13:24 1ea317d65ea5 zmwatch[16479]: ERR [Memory map file '/dev/shm/zm.mmap.1' does not exist in zmMemAttach.  zmc might not be running.]
Aug 20 18:13:24 1ea317d65ea5 zmwatch[16479]: INF [Restarting capture daemon for Garageuppfart, shared data not valid]
Aug 20 18:14:47 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 53 seconds (1629476087-1629476034)]
Aug 20 18:55:05 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 49 seconds (1629478503-1629478454)]
Aug 20 18:55:23 1ea317d65ea5 zmwatch[16479]: ERR [Memory map file '/dev/shm/zm.mmap.1' does not exist in zmMemAttach.  zmc might not be running.]
Aug 20 18:55:23 1ea317d65ea5 zmwatch[16479]: INF [Restarting capture daemon for Garageuppfart, shared data not valid]
Aug 20 20:23:38 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 53 seconds (1629483816-1629483763)]
Aug 20 20:23:51 1ea317d65ea5 zmwatch[16479]: ERR [Memory map file '/dev/shm/zm.mmap.1' does not exist in zmMemAttach.  zmc might not be running.]
Aug 20 20:23:51 1ea317d65ea5 zmwatch[16479]: INF [Restarting capture daemon for Garageuppfart, shared data not valid]
Aug 20 20:35:16 1ea317d65ea5 zmwatch[16479]: WAR [Restarting capture daemon for Garageuppfart, time since last capture 49 seconds (1629484516-1629484467)]
I'll try debug logging some time during the weekend to see if I find something.
