Grayed out alert frames
Technoholic
Post by Technoholic »
Just rebuilt my system using freshly formatted drives, Ubuntu 20.04 server and Zoneminder 26.5. Things run fine except for alert playback where the alert frames are grayed out. Non-alert frames playback normally. I am stumped. Please help.
Technoholic
Re: Grayed out alert frames
It looks like I found the fix. Under Source>Method change UDP to TCP. ONVIF had designatedd UDP during initial setup so I left it at that. Turns out TCP is a better choice.
