The Zoneminder master 1.37.1~20210830133533-bionic released today ( 31-8-2021) can not be installed due to some missing dependent software .
Please see the error logs below.
Zoneminder master 1.37.1~20210830133533-bionic - Can't install [ Solved ]
- bkjaya1952
Re: Zoneminder master 1.37.1~20210830133533-bionic - Can't install
I don't know what libnghttp is . the issue is outside of zm though.
- bkjaya1952
- bkjaya1952
Thank you Sir !
It was my fault. I have made a mistake when updating my docker repository https://hub.docker.com/r/bkjaya1952/doc ... 5.7-php7.2.
The Zoneminder master 1.37.1~20210830133533-bionic is working perfectly !
sorry for my mistake
Re: Zoneminder master 1.37.1~20210830133533-bionic - Can't install [ Solved ]
Are you running anything using Video Writer with h264 libx264?The Zoneminder master 1.37.1~20210830133533-bionic is working perfectly !
On my focal install all the frames are scrunched into the first couple of seconds of the mp4, or it has just the first frame for the whole thing.
Reverting to 1.36.5 on the same machine makes it work ok. I suppose it's related to a different version of ffmpeg.
- bkjaya1952
Yes dougmccrary.dougmccrary wrote: ↑Mon Sep 06, 2021 7:17 amAre you running anything using Video Writer with h264 libx264?The Zoneminder master 1.37.1~20210830133533-bionic is working perfectly !
I guess it's focal specific then.
Thanks.
Thanks.
I neglected to check this after the previous update - it was working on that and continues to work with today's 1.37.1~20210925142851-focal
Yay!
Yay!
