Hello , I have a total of 8 camera and all of them is able to display video. However, i have 2 camera that keep occuring end of file error.
if we look at console, all camera is online. But only these 2 camera is showing error every minutes and image is on and off for a few seconds.
is it because the camera is streaming at 2560x1440 resolution? it happens that these 2 camera are streaming at this resolution while other camera are streaming at 1080.
Camera Error ( End Of File )
- 05.10.2021_00.20.31_REC.png (67.19 KiB) Viewed 1688 times
- 05.10.2021_00.19.40_REC.png (101.13 KiB) Viewed 1688 times
- 05.10.2021_00.19.11_REC.png (176.48 KiB) Viewed 1688 times
Re: Camera Error ( End Of File )
Have you tried streaming the 2 cameras at 1080 to see if that helps fix the issue?
i could not change the resolution.
it is fixed at 2560x1440.
attached is my camera setting ( translated in english )
- 06.10.2021_20.56.36_REC.png (29.09 KiB) Viewed 1648 times
Does cam have a secondary stream - can you use that?
Maybe also try reducing the framerates, which seem to vary quite a lot.
