Swann swnvk-800kh4 NVR
dcung
Post by dcung »
I have the following system.
https://www.swann.com/au/swnvk-800kh4
It does not have Linux app, so I'm tyring to use Zoneminder with BusterDog (puppylinux). I got Zoneminder up and running following this guide
https://wiki.zoneminder.com/Debian_10_B ... om_ZM_Repo
I can use VLC to see live view of channels of the NVR.
rtsp://user:mypassword@ip-address:554/ch01/1
I have tried to add in Zoneminder (it says v1.36.7), but so far have not been able to see anything. I don't know if I do the config correctly.
I'm a newbie in security camera system.
Thank you.
Re: Swann swnvk-800kh4 NVR
I sent a post over at the Puppy Linux forum to see if we can get your system going.
dcung
Post by dcung »
dcung
Post by dcung »
My zoneminder installation (v1.36.7) in PuppyLinux (BusterDog) is auto starting atm.
While exploring/tinkering zoneminder, I'd like to start it manually for the time being.
Meanwhile, I run 'service zoneminder stop' after finish booting/rebooting (or I can stop it thru WebGUI).
I'm trying to locate where it gets started from during boot, so I can comment out the line (or modify ?).
Not sure whether more appropriate to ask in Zoneminder or Puppy forum...so I ask on both.
https://forum.puppylinux.com/viewtopic. ... 068#p39068
Thank you.
dcung
Post by dcung »
Fred posted the solution in Puppy Linux forum. Thank you Fred.
https://forum.puppylinux.com/viewtopic. ... 098#p39098
