- 42A35A86-4991-4E48-A18E-5B242B324648.png (88.25 KiB) Viewed 10794 times
High DB usage
Re: High DB usage
just got 1.37.1~20211016164753-focal.
Usage stayed high, do did a reboot. Mariadb took 10 minutes to stop.
So far, so good.
Thanks, Isaac!
So far, so good.
Thanks, Isaac!
Re: High DB usage
I wish someone with bootstrap or css skills would take some time and fixup our layout... I can do it, there is just too much to do though.
Anyways... you can bump up your db limits.... what is underlying your db, spinning rust or ssd? I've been finding that a lagging db due to spinning rust can really bog down ZM. I'm going to have to further optimise db accesses. Only so much I can do though.
Re: High DB usage
It's on the same (type) 120mb ssd that was using maybe 30 or so two revisions back, and a TB disk. This seems to settle down around 60-70, or more if there's a lot of motion going on.
Up until a crash a week or so ago, I was on mySQL, but I went with MariaDB per you saying it was faster,
Maybe I should go back to mysql to see if it matters?
Re: High DB usage
For the db connection count to be that high, there has to be that many zm processes accessing it. In 1.34, there was a zmc and a zma for each monitor. Now we just have zmc, so the number should be half of what it was in 1.34.
ps ax | grep zm
how many processes? I wonder if you have the zmu hanging around issue?
ps ax | grep zm
Re: High DB usage
There were about 67 connects, according to the web interface, when I got:
doug@doug-System-ZMX:~$ ps ax | grep zm
1093 ? S 0:50 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
1404 ? S 1:20 /usr/bin/perl -wT /usr/bin/zmwatch.pl
1430 ? S 0:00 /usr/bin/perl -wT /usr/bin/zmupdate.pl -c
1447 ? S 0:02 /usr/bin/perl -wT /usr/bin/zmstats.pl
22683 ? SLl 453:51 /usr/bin/zmc -m 9
23807 ? SLl 111:05 /usr/bin/zmc -m 3
24033 ? SLl 88:31 /usr/bin/zmc -m 13
24048 ? SLl 446:08 /usr/bin/zmc -m 11
24054 ? SLl 421:46 /usr/bin/zmc -m 10
24055 ? SLl 113:13 /usr/bin/zmc -m 1
24161 ? SLl 108:16 /usr/bin/zmc -m 8
24175 ? SLl 107:24 /usr/bin/zmc -m 2
24198 ? SLl 76:27 /usr/bin/zmc -m 4
24210 ? SLl 122:03 /usr/bin/zmc -m 14
24226 ? SLl 119:47 /usr/bin/zmc -m 15
36792 ? SLl 103:05 /usr/bin/zmc -m 5
36917 ? SLl 292:20 /usr/bin/zmc -m 7
58748 ? S 0:00 /usr/bin/perl -wT /usr/bin/zmtelemetry.pl
58751 ? S 0:03 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=1 --daemon
58752 ? S 8:52 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=3 --daemon
58757 ? S 0:04 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=2 --daemon
58831 ? SLl 21:29 /usr/lib/zoneminder/cgi-bin/nph-zms
59362 ? SLl 14:35 /usr/lib/zoneminder/cgi-bin/nph-zms
59386 ? SLl 21:48 /usr/lib/zoneminder/cgi-bin/nph-zms
59395 ? SLl 11:16 /usr/lib/zoneminder/cgi-bin/nph-zms
59397 ? SLl 10:56 /usr/lib/zoneminder/cgi-bin/nph-zms
60960 ? SLl 2:08 /usr/lib/zoneminder/cgi-bin/nph-zms
61827 ? SLl 20:14 /usr/lib/zoneminder/cgi-bin/nph-zms
65449 ? SLl 5:46 /usr/lib/zoneminder/cgi-bin/nph-zms
69407 ? SLl 4:20 /usr/lib/zoneminder/cgi-bin/nph-zms
69786 ? SLl 1:37 /usr/lib/zoneminder/cgi-bin/nph-zms
70281 ? SLl 2:28 /usr/bin/zmc -m 6
70315 ? SLl 0:54 /usr/lib/zoneminder/cgi-bin/nph-zms
71204 ? SLl 0:12 /usr/lib/zoneminder/cgi-bin/nph-zms
71206 ? SLl 0:05 /usr/lib/zoneminder/cgi-bin/nph-zms
71207 ? SLl 0:06 /usr/lib/zoneminder/cgi-bin/nph-zms
71209 ? SLl 0:02 /usr/lib/zoneminder/cgi-bin/nph-zms
71211 ? SLl 0:05 /usr/lib/zoneminder/cgi-bin/nph-zms
71212 ? SLl 0:04 /usr/lib/zoneminder/cgi-bin/nph-zms
71213 ? SLl 0:10 /usr/lib/zoneminder/cgi-bin/nph-zms
71214 ? SLl 0:25 /usr/lib/zoneminder/cgi-bin/nph-zms
71215 ? SLl 0:04 /usr/lib/zoneminder/cgi-bin/nph-zms
71216 ? SLl 0:11 /usr/lib/zoneminder/cgi-bin/nph-zms
71217 ? SLl 0:05 /usr/lib/zoneminder/cgi-bin/nph-zms
71218 ? SLl 0:05 /usr/lib/zoneminder/cgi-bin/nph-zms
71219 ? RLl 0:11 /usr/lib/zoneminder/cgi-bin/nph-zms
72221 ? SLl 0:00 /usr/lib/zoneminder/cgi-bin/nph-zms
72227 pts/0 S+ 0:00 grep --color=auto zm
Re: High DB usage
Do you have a lot of watching clients/monitors? My nph-zms processes go up as I fire up ZMNinja or other clients. They drop back down again quickly on 1.36.8.
If not, they must be hanging around when not needed.
Re: High DB usage
I have 14 assorted rtsp cams in mocord. 3 decode for timestamp, the rest passthrough, with jpegs either disabled or analysis only.
The same setup uses 20-30 DB on 1.36.8
Update:
For reasons I do not understand, 1.36.9 and 1.37.1 latest are now running almost neck and neck at 45-50 DB although the latter tends to run around 5 or so higher than 1.36. Both systems use the same settings and cameras, AFAIK.
Memory and swap nee /dev/shm is a nice change, BTW.
Update:
