Manufacturers and Models
Development Update:
I just merged some code I've been working on for a while, which basically just adds Manufacturer and Model to each monitor. There is a very small sampling of data included, but you can enter your own.
The idea is actually to use this and telemetry to crowd-source a database of models supported by ZoneMinder and useful source url patterns for them.
So please if you will, enter in manufacturer and model for your monitors and enable telemetry.
Perhaps I should add a camera rating as well? What do you think?
Re: Manufacturers and Models
Cool.
I always say get everything you *might* want right off. So maybe not just a rating, but a fair size remarks field. Or is that "Notes"?
A lot of the cams I have are pretty much identified by their app. E.G. YCC365 Plus
and different firmware versions, but "CloudCam". So, YCC for make and what they call "Model type" = "CloudCam" for model?
Do the best you can.
I'm going to have to cherry pick the submissions into the format list. Too many people will enter garbage.
