Can't install on Ubuntu 20.04
junior466
Post by junior466 »
I am following this https://wiki.zoneminder.com/Ubuntu_Serv ... der_1.34.x guide after installing lamp using:
sudo apt-get install tasksel
sudo tasksel install lamp-server
It simply gives me the following when visiting the page:
ZoneMinder Error
Unable to connect to ZM db using dsn mysql:host=localhost;dbname=zm
could not find driver
ZoneMinder will retry connection in 28 seconds.
Any ideas?
Re: Can't install on Ubuntu 20.04
Hmm. That ordinarily works. You did sudo su before starting?
Did you install 1.34 or 1.36? IOW, did you mod the script for 1.36?
junior466
Post by junior466 »
I did not use sudo su. I tried installing 1.34.
If you use MySQL there may be some issues. I recommend Mariadb. Use: sudo apt install apache2 php mariadb-server php-mysql libapache2-mod-php
Better instructions: https://wiki.zoneminder.com/Ubuntu_Serv ... der_1.36.x
