Thank you very much for your reply. Everything is clear.
I even wanted to do it all with groups.
But what stops me now is that all my servers are showing the problem with apache semaphores.
Maybe doubling the number of cameras will require more semaphores.
viewtopic.php?f=43&t=31330
Load on the server
Re: Load on the server
Also.
Everything is clear here about recording the stream through in mp4. But for the second stream, to view it in montage mode, what should I specify as a source? MJPEG or JPEG or something else?
It is clear that the resolution and frame rate should be less. Since in place of 16 sources there will be 32.
