Montage 1.37.1~20211110171217
FYI montage not working, but clicking show zones, zone mask shows but still no image
Jimmy
Jimmy
Re: Montage 1.37.1~20211110171217
Flash player, huh?
This was an upgrade from a immediate previous version
Jimmy
Jimmy
Did you try running zmupdate again?
Montage works on Ubuntu.
Will try, Montage Review is workong
"Database already at version 1.37.1, update skipped."
Chrome shown above
Firefox no error shown like above, just shows "State: - fps"
Jimmy
Chrome shown above
Jimmy
clearly there is a javascript error of some kind.
Error still there after last 3 updates
Is it on my end ?
Jimmy
Is it on my end ?
Jimmy
Would you be running multi port?
You could verify that’s not messed up.
If not, then I’d try un- reinstalling ZM.
multi port? don't know what it is
only one wifi camera on Mint 20.2, test box
been working fine, no changes just zm master updates
Okay - then if the logs aren't telling you anything, try reinstalling just ZM ( not lamp ).
Something went haywire on one of my machines just doing updates a few days ago, and I wound up reinstalling from scratch. But that was ufw, not zm.
BTW, is that a server box or desktop?
As I said, there is a javascript error. I can tell because various javascript libraries have not styled the widget correctly.
Right click, inspect element, choose console tab... see what there is..
I tried to look but did not know what I was lookin for
I solved it by wiping the PC starting fresh for ZM and a new Point of Sale software Dev testing.
I did notice some changes like the location geoip is working now and a few other fields not present before, so I don't think I was getting fully upgraded.
I only have 1 camera but for others can someone export the monitor & zones tables t, then re-import them to save time on multiple cameras, providing there is no changes to those tables. I use Beyond Compare
Tanks for your help
Jimmy
You should be able to run zmupdate on the imported table/db to fix any differences. at least within a few "releases".
