Everything installed OK, permissions look fine--must be something minor.
Warning: fopen(/usr/local/etc/zm.conf): failed to open stream: Permission denied in /usr/local/apache2/htdocs/zm_config.php on line 29
Could not open config file.
Error Message in Browser
Did you ever figure this one out? I'm getting the same identical thing on a brand new system (Slackware 10.1) - I get 'Could not open config file' in my browser when I try to open the URL and the following is in the /var/log/apache/error_log There are no errors shown in any of the ZM log files.
(Note: I've got a RAID set up under /video and that's where I've got apache and zoneminder pointed for the web root directory, which is why /video/html-root is listed as the location of zmconfig.php)
I'm running Apache 1.3.33 and PHP 4.3.10 as shipped with slack 10.1, although I'm fairly certain these aren't the culprits as I have another ZM box runinng the same combination that never had this problem. That machine is running 1.21.0 though - I put 1.21.3 on this new one.
I've even su-ed to apache and cat-ed the file to verify that it's not a file system-level permission problem. I'm going to continue investigating, but I'm not real sure where to go from here and could use some help to at least point me in the right direction if not solve the problem. This is the only post that came up in a search for this problem.
[error] PHP Warning: fopen(/usr/local/etc/zm.conf): failed to open stream: Permission denied in /video/html-root/zmconfig.php on line 29
*THAT*'s interesting... I have apache set to start at boot time; I never changed this from the default behavior. The first one is firing as root and the child processes are starting up as 'nobody'. I would be willing to bet that you hit the nail right on the head with that one cordel.
Now how do I go about changing what user a startup process runs as??? (It's not something that I've ever had need to do before.)
couple things, If this has been running a while something must have changed. check the config dir for apache ( /etc/httpd/conf or maybe /etc/apache/conf ) and see if there is a backed up version of httpd.conf
There are two possible settings in the file:
Both in /etc/httpd/conf/httpd.conf
First is the user and group settings, that tell apache what to run as.
Second is a new directives that is not fully functioning yet that you want to make sure your not makeing use of is AssignUserID and ChildPerUserID ( I really wish these worked )
Before changing anything, make sure you backup this file.
cp /etc/httpd/conf/httpd.conf /etc/httpd/conf/httpd.conf.backup
Regards,
Cordel
Regards,
Cordel
Nevermind - found it.
/etc/apache/httpd.conf has a User and Group option in it that you can set to what user to run apache as.
Changed these, restarted the daemons, and voila! No more problem and the zoneminder console pops right up.
Thanks for your help Cordel.
*edit - DOH! I was too slow to save you the work of typing. Thanks again though.*
