Zoneminder master 1.37.10~20220124093136-focal can't create USB camera monitor[Solved]
- bkjaya1952
I have tested the Zoneminder master 1.37.10~20220124093136-focal , the latest release , with a USB camera today and found the following difficulties
1.The USB Camera monitor can't be created .
2. The Error logging is nit working
3. In the filters ,you can't add conditions by pressing + button
some screenshots are given below
Re: Zoneminder master 1.37.10~20220124093136-focal can't create USB camera monitor
Works here on my system, FYI.3. In the filters ,you can't add conditions by pressing + button
- bkjaya1952
Hi dougmccrarydougmccrary wrote: ↑Wed Jan 26, 2022 6:32 amWorks here on my system, FYI.3. In the filters ,you can't add conditions by pressing + button
My test was on a fresh install . Not an upgrade.
- bkjaya1952
Still the same problems prevail in Zoneminder-master latest 1.37.10~20220126213942 -focal as well
Please check javascript console for errors.
- bkjaya1952
None of those are related to ZM.
How about view page source and look for php errors in the javascript code at the bottom?
- bkjaya1952
For the latest of Zonemider master 1.37.10~20220131141528-focal released today
Figure:- 1 .Page source -of monitor page
Figure:- 2 javascript console
Some config entry has a new line in it.
Try latest build which escapes them.
- bkjaya1952
Thank you very much Sir
I have tested the latest Zoneminder-master with Ubuntu impish , bionic and focal
The problem has been solved in the latest Zoneminder-master latest 1.37.10~20220201140734-impish & bionic
There is a small problem in installing Zoneminder Zoneminder-master latest 1.37.10~20220201140734-focal as there is a dependency issue.
(the following packages have unmet dependencies: software-properties-common : depends: gir1.2-glib-2.0 but it is not installable depends: gir1.2-packagekitglib-1.0 (>= 1.1.0-2) but it is not going to be installed depends: packagekit but it is not going to be installed depends: python3 but it is not installable depends: python3-dbus but it is not installable depends: python3-gi but it is not installable depends: python3-requests-unixsocket but it is not installable depends: python3-software-properties (= 0.98.9.2) but it is not going to be installed depends: python3:any but it is not installable )
That's weird. We havn't really altered the dependencies much in a long time.
Further it is saying that it can't install python3. That's kindof a major package.
- bkjaya1952
Thank you very much Sir !
The above problem has been solved in the latest Zoneminder-master 1.37.11~20220202205903-focal released today!
