1.37.11 main - big improvement - Thanks!
lyallp
Post by lyallp »
Still having the image corruption when watching events of Actual size or larger, but from my perspective, everything else is back to working.
...Lyall
TheRoth
Re: 1.37.11 main - big improvement - Thanks!
Post by TheRoth »
Hi
but it's not working for me (All camera not running)... Debian Bullseye Last Stable Version ... ZM Version: 1.37.11~20220203.75-bullseye
2022-02-03 15:03:54	zmdc		1020	ERR	'zmc -m 11' exited abnormally, exit status 255	zmdc.pl	-
2022-02-03 15:03:54	zmc_m11		9623	ERR	No monitors found	zmc.cpp	212
2022-02-03 15:03:54	zmc_m11		9623	ERR	Can't use query result: Unknown column 'Capturing' in 'field list'	zm_monitor.cpp	939
2022-02-03 15:03:54	zmc_m11		9623	ERR	Can't run query: Unknown column 'Capturing' in 'field list'	zm_db.cpp	129
2022-02-03 15:03:54	zmdc		9623	INF	'zmc -m 11' started at 22/02/03 15:03:54	zmdc.pl	-
2022-02-03 15:03:54	zmdc		1020	INF	'zmc -m 11' starting at 22/02/03 15:03:54, pid = 9623	zmdc.pl	-
2022-02-03 15:03:54	zmdc		1020	INF	Starting pending process, zmc -m 11	zmdc.pl	-
2022-02-03 15:03:53	zmdc		1020	ERR	'zmc -m 10' exited abnormally, exit status 255	zmdc.pl	-
2022-02-03 15:03:53	zmc_m10		9620	ERR	No monitors found	zmc.cpp	212
2022-02-03 15:03:53	zmc_m10		9620	ERR	Can't use query result: Unknown column 'Capturing' in 'field list'	zm_monitor.cpp	939
2022-02-03 15:03:53	zmc_m10		9620	ERR	Can't run query: Unknown column 'Capturing' in 'field list'	zm_db.cpp	129
2022-02-03 15:03:53	zmdc		9620	INF	'zmc -m 10' started at 22/02/03 15:03:53	zmdc.pl	-
2022-02-03 15:03:53	zmdc		1020	INF	'zmc -m 10' starting at 22/02/03 15:03:53, pid = 9620	zmdc.pl	-
2022-02-03 15:03:53	zmdc		1020	INF	Starting pending process, zmc -m 10	zmdc.pl	-
2022-02-03 15:03:52	zmdc		1020	ERR	'zmc -m 6' exited abnormally, exit status 255	zmdc.pl	-
2022-02-03 15:03:52	zmdc		1020	ERR	'zmc -m 8' exited abnormally, exit status 255	zmdc.pl	-
2022-02-03 15:03:52	zmc_m6		9612	ERR	No monitors found	zmc.cpp	212
Uh... that capturing stuff is from an experimental branch of mine... I think it must be building packages from it. Not good.
Should be some new packages available in a few minutes that are true master.
TheRoth
Post by TheRoth »
Hi Thanks !
I tried the new update(1.37.11~20220203.86-bullseye) and it's still not running :(
2022-02-03 21:43:12	zms_m1		4290	ERR	Unable to load monitor id 1 for streaming	zm_stream.cpp	45
2022-02-03 21:43:12	zms_m1		4290	ERR	Can't use query result: Unknown column 'Capturing' in 'field list'	zm_monitor.cpp	939
2022-02-03 21:43:12	zms_m1		4290	ERR	Can't run query: Unknown column 'Capturing' in 'field list'	zm_db.cpp	129
2022-02-03 21:43:12	zms_m2		4288	ERR	Unable to load monitor id 2 for streaming	zm_stream.cpp	45
2022-02-03 21:43:12	zms_m2		4288	ERR	Can't use query result: Unknown column 'Capturing' in 'field list'	zm_monitor.cpp	939
2022-02-03 21:43:12	zms_m2		4288	ERR	Can't run query: Unknown column 'Capturing' in 'field list'	zm_db.cpp	129
2022-02-03 21:43:09	zmdc		1031	ERR	'zmc -m 11' exited abnormally, exit status 255	zmdc.pl	-
2022-02-03 21:43:09	zmc_m11		4286	ERR	No monitors found	zmc.cpp	212
2022-02-03 21:43:09	zmc_m11		4286	ERR	Can't use query result: Unknown column 'Capturing' in 'field list'	zm_monitor.cpp	939
2022-02-03 21:43:09	zmc_m11		4286	ERR	Can't run query: Unknown column 'Capturing' in 'field list'	zm_db.cpp	129
2022-02-03 21:43:09	zmdc		4286	INF	'zmc -m 11' started at 22/02/03 21:43:09	zmdc.pl	-
2022-02-03 21:43:09	zmdc		1031	INF	'zmc -m 11' starting at 22/02/03 21:43:09, pid = 4286	zmdc.pl	-
2022-02-03 21:43:09	zmdc		1031	INF	Starting pending process, zmc -m 11	zmdc.pl	-
2022-02-03 21:43:09	zms_m6		4284	ERR	Unable to load monitor id 6 for streaming	zm_stream.cpp	45
2022-02-03 21:43:09	zms_m6		4284	ERR	Can't use query result: Unknown column 'Capturing' in 'field list'	zm_monitor.cpp	939
2022-02-03 21:43:09	zms_m6		4284	ERR	Can't run query: Unknown column 'Capturing' in 'field list'	zm_db.cpp	129
2022-02-03 21:43:08	zmdc		1031	ERR	'zmc -m 11' exited abnormally, exit status 255	zmdc.pl	-
2022-02-03 21:43:08	zmc_m11		4282	ERR	No monitors found	zmc.cpp	212
2022-02-03 21:43:08	zmc_m11		4282	ERR	Can't use query result: Unknown column 'Capturing' in 'field list'	zm_monitor.cpp	939
2022-02-03 21:43:08	zmc_m11		4282	ERR	Can't run query: Unknown column 'Capturing' in 'field list'	zm_db.cpp	129
20
TheRoth - there may be a newer one.
1.37.11~20220203175409-focal
is working better for me.
bkjaya1952
Post by bkjaya1952 »
dougmccrary wrote: Fri Feb 04, 2022 1:47 am TheRoth - there may be a newer one.
Yes !
bkjaya1952
For impish , focal , bionic as well
Yes !
TheRoth
Post by TheRoth »
1.37.11~20220205.20-bullseye
Works very well ^^ Thanks :)
TheRoth
Post by TheRoth »
Same problem with the last update (maybe little different)...
1.37.11~20220214.143-bullseye
2022-02-14 20:48:26	zms_m9		1999725	WAR	Using slow std functions	zm_image.cpp	98
2022-02-14 20:48:26	zms_m8		1999721	WAR	Using slow std functions	zm_image.cpp	98
2022-02-14 20:48:26	zms_m7		1999720	WAR	Using slow std functions	zm_image.cpp	98
2022-02-14 20:48:26	zms_m2		1999719	WAR	Using slow std functions
2022-02-14 20:47:57	zms_m1		1999680	ERR	Can't open memory map file /dev/shm/zm.mmap.1: No such file or directory	zm_monitor.cpp	798
2022-02-14 20:47:57	zms_m4		1999678	ERR	Unable to connect to monitor id 4 for streaming	zm_stream.cpp	59
2022-02-14 20:47:57	zms_m4		1999678	ERR	Can't open memory map file /dev/shm/zm.mmap.4: No such file or directory	zm_monitor.cpp	798
2022-02-14 20:47:57	zms_m11		1999676	ERR	Unable to connect to monitor id 11 for streaming	zm_stream.cpp	59
2022-02-14 20:47:57	zms_m11		1999676	ERR	Can't open memory map file /dev/shm/zm.mmap.11: No such file or directory
Part of that is the fresh debug messages just dropped in to show up slow non-SSE functions.
