I have accidentally restricted the monitors for my admin account and now I can not seem to undo it. The user "Restricted Monitor" option list does have a way to unhighlight a highlighted monitor. So once a monitor is selected and saved, the account goes into restricted monitor mode forever.
After this happens, admin can no longer add new cameras/monitors. The system "edit" users option also does not seem to help.
I have the following software configuration:
zoneminder 1.24.2
firefox 3.0.17
Unbuntu 9.04
Restricted Monitor Problem
If the usual holding [ctrl] and deselecting don't work, you can update the DB directly:
mysql zm
UPDATE Users SET MonitorsIds="" WHERE Username=Admin;
exit
Ok, I will admit that I tried a new user ID before my original post as part of the debug process. And that did give me access to additional cameras/monitors. It just seemed excessive for fixing the problem consider how easy it was to get into the problem.
Since the last reply I also tried the control key method, and it worked. However I still think that the user interface could still be improved in this area.
Re:
Note: I ran into this issue and used the above mysql instruction to fix the issue but it took me a few times to get it right until I corrected the following things:cordel wrote: ↑Sun Jan 24, 2010 3:46 am If the usual holding [ctrl] and deselecting don't work, you can update the DB directly:Code: Select all
mysql zm UPDATE Users SET MonitorsIds="" WHERE Username=Admin; exit
1. The column is MonitorIds, not MonitorsIds
2. Admin needs to be in quotes.
MySQL Server version: 8.0.28-0ubuntu0.20.04.3 (Ubuntu)
