1.37.12 No data found in range
haolli
Post by haolli »
Thank you for this great project. But now I have a big problem. 2 days ago our system was updated from 1.35.xx to 1.37.12. 1.35 has worked great for a very long time. Unfortunately we did not know that the 1.37. is a developer branch. The 1.37.12 has now worked for about 2 days, but since today no more saved data is displayed. We have installed a 12TB hard disk, which is kept at 95% by a filter. The complete configuration of all 6 cameras was taken over during the update. What do we have to set so that data can be recorded on the hard disk again? Unfortunately, our installation is not a hobby.
BR
Olli
Re: 1.37.12 No data found in range
Yes, 1.37 is pretty broken at the moment. If 1.35 was working for you, you want 1.36.
Uninstall zoneminder and then download and install 1.36 (or even 1.35).
You'll need to enable zm and configure apache to it
You may then get database errors - running zmupdate.pl should make it right.
Even numbered versions are releases, and odd numbered versions are development versions.
