service zoneminder fail starting
bensz
Post by bensz »
I have a debian buster with zm 1.36.5
It worked correctly until I had a full disk in /var (in fact it was inode full). I erased files to have free space and inodes. But now I can't start service zoneminder. As this computer is not connected to internet, I attach screen captures with logs.
In firefox, I have a blank screen.
As you can see, I have error message for mariadb, mariadb works correctly, but le table Logs is empty.
Thanks for help and ideas.
Benoit
Maximo1970
Re: service zoneminder fail starting
Post by Maximo1970 »
It would be worth checking the service configuration for Zoneminder and check to see that all the requirements are available. On my setup I have SQL running on anther server and need to comment out the requirement for the Zoenminder service to start.
I'd start with running mysqlcheck against the DB.
bensz
Post by bensz »
hello,
Thanks for ideas. I tried the check for mariadb, but everything is right. For checking config, it must be right because zm worked correctly before my "disk full".
Benoit
Did you empty trash? Your disk might still be full.
bensz
Post by bensz »
normally, no problem as I used rm in terminal and df an df -i said I have free space.
Benoit
You'll have to tackle to DB the way I see it.
You could see what the value is that it's trying to use -
SELECT `AUTO_INCREMENT` FROM  INFORMATION_SCHEMA.TABLES WHERE TABLE_SCHEMA = 'zm' AND   TABLE_NAME   = 'Logs';
and see if that's the problem for the table.
